voice navigation
Old Nov 8, 2000 | 12:40 PM
fred3113's Avatar
Question voice navigation
The factory amp and speakers is just not loud enough for me and i have been thinking of replacing them. I have talked to some people and even the dealer whom have told me that if i change my amp, i will lose the voice of the navigation, if that is the case i don't want to do that. Does anyone have any input on this?
Old Nov 8, 2000 | 02:46 PM
MToker's Avatar
Post
I didn't lose voice all together I just lost the ability to mute, but there are a few people who have worked around that.
Anyone wanna share?
2000 Laguana Green / NAVI, 2 x JL12W6s, Pioneer Premier P920R, MB Quarts Coaxial, PPI 2600.2 and 4400.2 , Pioneer 620 6Disc
My Acura
Old Nov 9, 2000 | 02:14 AM
Water Rabbit's Avatar
Wow only on my 2nd tranny
Smile
If you replace the factory amp and speakers you can still have the the navigation voice working just like before.
If you replace the head unit then the voice gets lost. The solution to that is to install a little self anmplifiedAlpine speaker
Old Nov 9, 2000 | 02:53 AM
MToker's Avatar
Post
Ya just dont ground it other wise u get horrible engine noise. It self grounds off the RCAs I believe. I spent numerous hours today fiddling with it.
Old Nov 23, 2000 | 04:28 PM
SteveStMS's Avatar
Wink
I was able to get voice from navi on Panasonic CQ-DVR909U stereo for Honda mini-van. A TL should be the same - although I haven't confirmed this.. I need a TL 1st! You need to feed the audio signal (pins 2&3 on radio connector) to Aux-in L and R on your stereo or to your front L and R preamp outputs (before amp). The preamp method is prefered if you have mute circuit on your new stereo, otherwise you will need to switch to AUX for navi audio. For wiring to preamp the signal is pretty 'hot' so you should consider a 10K to 15K resistor in-line. To make the mute work test Pin 4 and if it's like the Honda you will get +12 when navi speaks. This can be a problem because todays stereo cell phone mute circuits expect GND to mute. Solve this by getting a little 12V reed relay + 1N4001 diode for across the coil from Radio Shack and switch the mute circuit to ground with this relay.
Old Nov 25, 2000 | 06:01 PM
MToker's Avatar
Post
I am gonna have to check my deck for this ability.
Thanks for the Info Steve
2000 Laguana Green / NAVI, Burlwood Shifter, 35% Mirror Tint all over,2 x JL12W6s, Pioneer Premier P920R, MB Quarts Coaxial, PPI 2600.2 and 4400.2 , Pioneer 620 6Disc
My Acura
dirleton
Aug 6, 2024 08:19 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
TLguy42
Sep 26, 2015 11:27 AM
