Video Screen Location
I was thinking of putting a video screen in the glovebox so when it is closed you keep the stock appearance. What is the biggest screen you think I could fit in it.
I have no idea other than the TSX glove box is small. I can barely fit my gun and the owners manual in there as it is. It has little depth too. I also have an Oakley vault crammed into the side as well.
I would have to say something on the small side. I know that is little help, but I have never tried the install you are describing.
I am not very good with photoshop yet but I am working on it. Here is another way i came up with of where to put a screen. What do you think.Mounted Screen
Glove box is too small... The pocket area would be hard to see with it being low and LCDs having fairly narrow vision fields...
I suggest, in asending order of complication:
a) sun visors
b) modifying the sunglassholder/lights/etc area for a flip down LCD.
c) removing the stock center air vents, re-routing the airflow to the side vents, and fabricating a mount for a motorized LCD in their place.
a) sun visors
you could mount the hazzard switch anywhere, you don't really use it that often... glove box perhaps?
The problem with the power screens in the lower pocket is that the gear shift can be in the way of it opening, and it might not clear the 'blue light' overhang area.
is there enough room for the motorized screen to come out all the way so you can see it from the drivers seat. and will it be able to angle up engouh to see it
will this screen come out enough http://cgi.ebay.com/ws/eBayISAPI.dll...category=14946
i like my way more.... 2 reasons...
1. I like to keep my vents where they are
2. Its illegal to have a screen on in view of the driver while the vehicle is in motion. Your screen is easily seen through the windows as on. My way its in sight of driver; and passenger and its outta sight for anyone who cares to look in while the car is in motion
will this screen come out far enough so that it can tilt to an angle that the driver would be able to see if i would install it where the compartment below the a/c controls are
Originally posted by 97AcuraCL
no but i dislike the motorized ones anyway. my screen will look a lot more custom as though the screen was meant to be there... goodd news is later on i can hook it up to an aftermarket navi system as well.
Originally posted by e_lectro
A 5.8" screen for an aftermarket navi mounted that low? Man that's gonna be hard to see...
i am liking this dvd player idea. soory to hi -jack your thread, but i have the navi with tv tuner conversion already installed. i currently use my playstation 2 under my seat to play dvds. i wonder if this dvd player could be an alternative...? any thoughts on where to mount in OTHER than the cd storage comparment?
the screen? not a one... there simply is no place to mount it unless you start cutting into the dash or doing something radical like getting rid of your vents. (not practical)
the only idea i could think of would be to have a piece of fiberglass made to make like a covering for it and put it ontop the vents and make it flow with the dash.
navtool.com
14
Oct 31, 2015 08:16 PM
