Video in navi???????????????????
if i use the RGB-1 decoder thing will i loose my navigation and only have video or is there a switch or something to go from navi 2 video.
thank you.
thank you.
You can use a 4PDT switch (sold on-line). When using this switch, the RGB1 decoder is mounted behind the dash.
OR
Use a 4PDT relay 12volt (sold at Radio Shack). The RGB1 and relay are mounted back with the navigation computer and wired up to a single pole dash mounted switch.
OR
The relay can be easier to install in the trunk than pulling your dash apart. You basically buy the relay and socket from Radio Shack and pre-wire the AVC-RGB1 to the correct socket pins. Also hook power wires on to energize the relay. This will leave you with 2 sets of 4 terminals to be connected between navi computer plug and wire harness going to the display unit. "Intercept" the 4 wires (White,Red,Yellow and Green) on the middle black plug of the navi computer.
Hi! I also am looking around of a DVD Player and Navi System in one. Is it worth to buy the system all in one or just buy the Player or Navi system then upgrade.
Moderator Alumnus
Re: HEY STEVE
Originally posted by goodbadmas
Hey STEVE,
can we hook up a laptop somehow to this decoder ? and see the laptop or do we have to get any other part ??
Hey STEVE,
LAPTOP
Actually, I do have 2 5.6" in the back of the headreast and just thought that may be .. i can do something neat with hooking up my laptop ... and hook up those 2 screens with the navi decoder and i dont' know ! still thinking .. i will talk to ron about it !
Thanks a lot for the info though !
08_UA7_Gr33k
02-11-2016 02:17 PM
lanechanger
10-13-2015 10:56 AM
