USA-Spec PA11-HON2 Engine Whine?
Old 12-13-2006, 08:15 AM
fuzzynoise's Avatar
I've got the PA-11 Hon2 hooked up to my car and it works great! However, does anyone else hear a engine whine when you listen to an AM station? If you don't where to you have the unit positioned at? Also, when I've got the stereo selected to use the Ipod, with the volume turned down, I can still hear a very faint whine, but it's so faint I don't hear it when I'm listening to the Ipod with the volume turned up. The only problem so far is really with AM. Any help? Suggestions? Thanks in advance!
Old 12-13-2006, 04:24 PM
TSX Sold! Hello STi!
amadeus303's Avatar
Is this your stock AM radio, or is this an AM radio that's hooked up to the aux inputs of the USASpec module? You probably just need a GLI (ground loop isolator) to go between your aux input and the USASpec module. I don't know if there's anything you can really do with regards to the iPod whine since that's a direct hook up to the module (i.e., I don't think there are any GLI-type devices that can be used in between the iPod and module).
Btw... what vehicle?
Old 12-14-2006, 07:16 AM
fuzzynoise's Avatar
Stock radio. I have the ipod hooked up, nothing on the aux inputs. I've got a 2005 w/nav
Old 12-14-2006, 02:14 PM
04rob's Avatar
I also have some slight engine whine with the USA SPEC, but on FM radio. Strange thing is it seems to come and go. It is definitely the USA SPEC because it immediately goes away when I unplug the unit. This is on an 04 TSX using the factory radio.
Old 12-14-2006, 03:03 PM
VP Electricity
elduderino's Avatar
There is an ECU below the radio on the hump that is a known emitter of electromagnetic interference. Move your module as far as you can from that airbag ECU.
Also, make sure the metal case of the USA SPEC is not grounding to any metal. I've seen one in a Volvo that had noise ONLY when the module was screwed to metal.
Old 12-15-2006, 01:01 PM
04rob's Avatar
I thought the location may be a problem, so I moved the USA SPEC unit. It now is just sitting under the passenger seat. Unfortionately, the whine persists. I'll have to see if the cables are routed near that unit.
Old 12-15-2006, 02:00 PM
Reach's Avatar
They'd have to be. The ECU is mounted on the floor's hump. To put it in the passenger area means you'd be pulling the cables right by the ECU.
I'd stick to the original location, but try fabricating something to shield it, or do a better job of stuffing the wires up behind the CD player instead of letting them hang.
SidhuSaaB
05-30-2020 12:40 AM
joflewbyu2
10-08-2015 11:16 AM
ROSSARONIE
10-02-2015 11:46 AM
TL14
09-24-2015 04:37 PM
STL TL-S
09-23-2015 08:52 PM
Quick Reply: USA-Spec PA11-HON2 Engine Whine?
