Unlock code for factory stereo doesn't work
Yes, i've used it in the past. One time I changed my battery and I had to input the code and recently i've changed the high beam light bulbs and had to remove the battery.
But last night when I tried to start my car it went dead all of a sudden. Opened the hood- a battery contact came loose - my bad - did not tighten it good enough.
When I tried to input the code - it started giving me errors - one after the other -" ERR 1 " - so forth.
Unplugged the battery again for 10 min - same story
Acura dealership doesn't know what else to do
Fuses are intact - it ejects CD's
HELP
HELP
291hp & 245 tq @ 3.5psi
Read this thread will help you to make it work again:
https://acurazine.com/forums/2g-tl-problems-fixes-117/radio-code-doesnt-work-602128/
I suggest you take it to a mechanic... he/she will then go to the dealer and get the code for you...(btw... make sure he is doesn't work for a major corporation... because they usually charge for it)
Unplug the radio antenna from the back of the radio turn the key on and enter the code. If it accepts it then put the antenna back in.
2003 TL-p
i really suggest removing the Bose cd changer and putting an aftermarket. there are threads hear that tell u how to get the sub to work with an after market. if the Bose unit you all have now isn't jamming cd's it will sometime. mine kept jamming the cd's, and i had to bang on the dash to free them up.
its just i have had so many problems with that stock Bose cd unit i highly suggest removing it before you get more problems. i mean if you cant get the code to work just get rid of it.
hope you dont run into any more problems
AndrewS
19
03-14-2024 06:59 PM
handsom-hustla
11-13-2015 05:04 PM
Gianni Formica
09-07-2015 08:28 PM
