TL: Tweaking stock stereo for aux 3.5mm input
Is it possible at all? I have 02 TL-S whose stereo as you know is pretty old. I wanna be able to plug in my smartphone and routed the sound to the car speaker. Thanks!
Okay I found some research and found some info. THere is a part called PXDX that might into TL. Could someone answer if TL-S 02 equipped with built-in CD changed or not (with the case of former, then device will not be compatible).
I someone could post the backside connectors picture here, that will be a gigantic help. Thanks!
wow. umm.. Does your car have a 6 disc in dash cd player? If so then you answered your own question.
If TL 2nd gen all has built-in CD changer, then why they say it is compatible with 2nd gen in the first place.
MechEng
honestly i think those AUX inputs are a waste. you could just spend the same or a little more and get a new head unit.
i use a $20 tape deck AUX adapter from Monster and it sounds more than exceptional. though it also depends on what smart phone you have. Sound quality improved greatly after switching from my old Samsung Eternity to my new iPhone 4.
but thats just my opinion. do whatever floats your boat...
well it is got 6 CD player slot in-dash. But what i dont know is that CD changer is separate or not. The compatibility for this part says ACURA TL 2nd gen is compatible but then says it is not compatible with player with built-in CD changer.
They are more expensive but the sound quality is better and it's a much cleaner install than a tape deck. Aftermarket radio is a option if you want to go that route but you would lose, without modification, steering wheel controls, sub, navigation voice prompts etc.
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
