Trunk Rattles!!
Old Oct 28, 2004 | 12:50 PM
volcomst0ne24's Avatar
Trunk Rattles!!
i hate it...the trunk rattles like mad with the subs and they dont even push that much. it sounds like total crap, is there anything i can do to remedy this? i did that little trick with the rubber knob things on the trunk but that only worked a little.
Old Oct 28, 2004 | 02:00 PM
spooky3ce's Avatar
Swift 3 B-A-N-G-E-R
Dyna-mat!!! other than that and the rubber knob trick i wouldn't know... There is this foam that also helps with rattles but i wouldn't recommend it because once it gets old it starts to fall apart. Old as in about 6 to 12 months old...
I recomment Dyna-mat the trunk and any other part of the car like the doors that will be effected by vibrations... but if you have the time and money then i recommend just doing the whole interior of the car and the whole trunk...
Old Nov 4, 2004 | 07:35 PM
Tennisjon2002's Avatar
I am having this problem in my 97 accord with my new subs. Is there any cheaper alternative to dynamat that is decent? I have heard only good things about dynamat but $100 is alot to pay for some foam in ur trunk. Anyone know of any decent sprays etc?
Old Nov 5, 2004 | 09:17 PM
big mike 13's Avatar
Peel n Seal... found at Lowes or a home depot or a roofing store..
Old Nov 5, 2004 | 10:01 PM
ou sig's Avatar
Boomer SOONER
I have dynamat all over my trunk...mine still rattles when I blast it.
Do a search, this topic is all over...but like I have said before, it is the subs moving the air inside your trunk that makes it rattle. The only thing you can do to get rid of it is point your subs either up (most mustangs have to get done like this), or point them toward the cabin. That being said, pointing them toward the back is ideal for sound levels.
So get some Dynamat, or something similar, and learn to live with it. The air pressure is just too much in an enclosed trunk to keep the trunk lid from moving.
Also, is your stock sub out? If not that will help to let some of the sound get into the cabin easier.
Old Nov 7, 2004 | 07:44 PM
So have u used this or is this just an idea?
Old Nov 9, 2004 | 08:30 PM
ive read a lot about it and i personally just bought a few rolls last week.. i installed one week and i feel it does help.. didnt finish my whole trunk yet, but it sounds louder inside with less rattles outside.
Old Nov 10, 2004 | 12:41 PM
lookin4tl's Avatar
i personally would recommend RAAMmat60.... www.raamaudio.com/products.htm It's 60ml thick and priced MUCH MUCH lower than Dynamat. I've had several friends use this and they all loved it!!
You can also try FATMAT www.fatmat.com It's only about 45ml thick but it's cheaper than even the RAAMmat.
Old Nov 10, 2004 | 12:43 PM
lookin4tl's Avatar
i have heard of peal and seal being used but it's very thin and might not give you the results your looking for. it is cheap tho!! :blaze:
Old Nov 16, 2004 | 07:48 PM
Where in lowes would peel n seal be? I mean what is it? isn't it some roofing thing. i think i am gonna go pick some up and try it out as a first step, but i don't want 2 go 2 lowes and not be able to find it.
Old Nov 16, 2004 | 08:02 PM
UnsanePyro's Avatar
Registered Driver
Originally Posted by UnsanePyro
Here...
http://www.caraudiolounge.com/index.php?showtopic=5083
Check a local hardware store for some "Peel N Seel" it's basically the same thing except amazingly cheaper. I
believe reading someone talked to the company that produces Peel N Seel and they said they sell product to a company whos focus is car audio. If I can find the link I'll show you.
edit: heres the link: http://www.caraudiolounge.com/index.php?showtopic=5146
I never got around to doing this on my old car, but I am seriously considering it on this car, especially once I have some extra money for a sub/amp.
Another post of mine on a smiliar subject, and yes, it should be in the roofing section. Read those threads over if you'd like, you would be suprised at what you may read.
Originally Posted by caraudiolounge
Its made for roofing but I plan to use it as Sound Dampening, It’s reminiscent of Dynamat Xtreme but a lot cheaper…
http://www.mfmbp.com/peelseal/
They are both a elastomeric butyl with an aluminum constrained-layer. I don’t see a lot of differences between the two but the price…
I called a manufacture that makes roofing products that are butadiene rubber based with an aluminum layer and a pressure sensitive adhesive backing.
It turns out that they also make the same product for two other companies that market the product for car audio vibration dampening. He couldn’t disclose who, which I understand, but it does prove a point.
I think those were the two biggest things, I am probably doing mine sometime this winter, at the same time as a sub/amp. Hopefully going to do the doors too
Old Nov 16, 2004 | 08:19 PM
Thanks that is useful info. i think i am gonna pick up some peel n seal and put it on this weekend or next week sometime. ill keep ya updated on how it turns out
Old Nov 16, 2004 | 10:28 PM
Is there anything else i should get with the peal and seal? I will get the roller but are there any sprays or anything i should get that would help stop vibration even more?
Old Nov 18, 2004 | 06:12 PM
I went to Lowes to get peal n seal and they didn't have any and they had never even heard of it!! then I called Home Depot and was on hold forever so then I drove over there and got the same answer!!! Where can I get this stuff for cheap?
baelim
May 10, 2018 09:53 AM
Jul 16, 2017 07:33 AM
jmaxima03
Sep 27, 2015 10:22 AM
justin.w13.walker
Sep 22, 2015 02:21 PM
