Trim Plate question
Old Aug 31, 2002 | 01:09 AM
blown65's Avatar
Trim Plate question
ok, yes I've used the search but cant seem to find the answer to this question. I have the dark interior with the blackwood trim. Where do you find either the plain black or blackwood material to make a faceplate for a deck install?
Old Aug 31, 2002 | 08:47 AM
shawhite's Avatar
you can find the blackwood at selectproducts.com more than likely.... and as far as the black it is plexi painted flat black....
Old Aug 31, 2002 | 01:52 PM
StreetEffectz's Avatar
Select products blackwood DOES NOT match, it is much lighter, and also the swirls are much larger so the pattern isn't quite the same. You can make an abs piece, and then send it to us and we can have it covered in the EXACT matching black burlwood to match the car.
Old Aug 31, 2002 | 02:35 PM
blown65's Avatar
Thanks street, Ill do that then. That way if I mess up the first time its no big deal.
Old Aug 31, 2002 | 10:31 PM
shawhite's Avatar
damn streetz is there anything that you havent ran across... i mean you are the holder of all knowledge.....
The Machine
Sep 24, 2018 08:27 PM
HOWELLiNC
3G TL Photograph Gallery
24
Oct 8, 2015 03:15 PM
Sep 17, 2015 09:01 PM
Sep 17, 2015 08:57 PM
datadr
Sep 12, 2015 09:12 PM
