Those with aftermarket subs -- What did you do with the factory built-in sub?
I'm getting subs installed in my car sometime this week, and I was wondering what I should do with the factory Bose sub in the back. I'm putting the aftermarket subs in the trunk, two 10"s, 800 watts. Nothing crazy, just for a little added bump. Should I leave the stock sub alone, or unhook it?
Thanks.
Thanks.
My opinion would be to at least unhook it. You can then decide if you want to remove it or not. I took mine out thinking it might allow some bass to filter in thru the hole but, I really did not notice any difference with it still in. But, I would for sure unhook it.
Received 1,080 Likes
I explored this very same issue last year. First of all, at the very least unplug the factory sub. Then the question of whether to leave it in or take it out and leave the hole open depends on the type of sub box you have.
I have a sealed sub enclosure and I can tell you that i experimented and your bass response will be much better with the stock sub left in. Bass response will be tighter.
Also to consider is that the factory sub, being left in but unplugged, will act as a passive radiator, given the air pressure generated in the trunk by your new subs. I am not sure if that is a good thing or not though. The one thing i have not had a chance to do is to make a steel plate, then remove the stock sub and place the plate over the stock sub opening to seal it up without the facotry sub. This would tell whether the passive radiator effect of the unplugged stock sub is beneficial or harmful to overall bass response.
If you have a ported sub enclosure, you will probably benefit by removing the stock sub and leaving the opening for the bass to vent into the interior.
kb1rl
09-30-2015 10:17 AM
