Third Party Cassette Player on TSX???
Couldnt find any info on this with the search... so here goes.
I am planning to install a thirdparty cassette player on the 05 TSX ($100 Vs $400 from Acura). Have any of u done this before?? Also the product I am looking at says 50Watts of power, but the TSX CD audio is 360 Watts. How does this work?? I am new to this electronics things, and would appreciate any help.
Mods, i wasnt sure if this should go into the Audio/Video section. But since its pertains to the TSX, I decided to post it here. Feel free to move it.
Not an Ashtray
http://www.handa-accessories.com/tsx.html
VP Electricity
1 Post
Yes, IMO it should be in AV.
The RIGHT way to do this (I use that term loosely, since I am not certain at all that there is a RIGHT way to install an aftermarket cassette into a TSX: ) is to pretend that the cassette player is an MP3 player. Run the preamp signal from the deck to the SHOND or Blitzsafe AUX adapter. That will be clean and simple, but you'll squawk at the cost, probably.
You HAVE to use a cassette player with RCA preamp output jacks for this to be clean and simple.
You would be far better off getting the OE cassette player. It would look much less steal-worthy, and the bracket would make mounting a snap. You need to buy the bracket anyway as a mounting kit for the cassette player.
Why on earth are you installing a cassette deck?
VP Electricity
1 Post
Oh, btw, leave all the speakers connected to the factory radio. Your cassette will add no watts, it will just be a source unit to your radio - like a DVD player you add to your home stereo.
Just dial 1911
1 Post
Eldu will be along im sure...
Edit: Jeez you guys are fast
such a dirty birdy
I know it seems like an odd thing to want to do, but my wife has remarked that a cassette player in the car would be nice because a lot of audiobooks aren't out on any other format.
VP Electricity
1 Post
I guess the combo of adding a cassette and using a $100 aftermarket unit is the challenge for me.
If you want the cassette option, you really should go with the OE kit. If you have the nav screen, the OSD will match when the cassette is selected, and regardless, it looks right and stealth and all that.
Go Giants
VP Electricity
1 Post
1) Your CC guy will NOT install it free for you. It is classified as a custom job (and should be).
2) That $200 will be eaten up by the SHOND or Blitzsafe adapter and the install charges.
3) That $200 is important to me too... that's why I'd use it to do this in the most appropriate way. Please don't imply that I don't care about money... I am talking about value.
4) You put a $100 radio in that dash and some night a crackhead might steal it for no good reason. I've seen crappy aftermarket radios stolen, but factory Hu's are rarely stolen. Why take that risk? Your car would be damaged.
5) The OE sound system is not designed to have an aftermarket radio replace the factory radio and still use the "340 watt" (cough cough bullshit cough cough) amplifier to run the 8 speakers. If it were wired in by a good installer, it might work out fine (assuming that you bought a radio with front and rear RCA outputs, but that is questionable for $100, maybe or maybe not). You also might have engine noise that would require multiple install visists to fix (if it is fixed, which I tend to think is possible but not attractive to commit to in order to earn a $100 sale...) , you certainly would lose your steering wheel controls, and the LCD indicator on the top of the dash would be useless (tells you station, source, track number, etc.)
So the preferred method is to add the SHOND or Blitzsafe AUX input adapter into the OE radio, or use the factory system into the OE radio. Anything else is much more complicated and not in your price range. I doubt the two are that far apart on cost once you do the math. The factory system looks better, works better (doesn't disable any functions), and installs better.
Or you could use an FM Modulator on your Walkman... that's cheap. Heck, you oculd use an FM Modulator on your aftermarket deck, but it's still an eyesore in the car.
Go Giants
Originally Posted by Tsx536
Get a SNHOND3, a Sony tape walkman, 2 AA batteries...and you're done!
Go Giants
.....I keep forgeting how bad a cassette tape sounds....It sounds like
That's a classic tape player picture you have by the way! wsklar
Rep'n Taxbrain.com
Don't forget the "Auto Reverse" feature. If you had a high end tape player with auto reverse. You were the man back in the day!
One thing I do miss is wrapping the cassette tape ribbon around my friends' car antennas when there weren't looking and then waving to them and laughing as they proceeded to drive away dragging about 1/4 of tape ribbon. That was just "classic"
Fool
03-10-2016 08:42 PM
GWEEDOspeedo
01-15-2016 10:39 PM
2004, acura, aftermarket, casette, cassete, cassette, install, navigation, player, players, required, thirdparty, tsx, tsxs, work
