Thinking of replacing my speakers
Old Oct 11, 2000 | 04:02 PM
Y2K_TL's Avatar
Post Thinking of replacing my speakers
When i am listening to soft music with low volume there is this hissing sound coming out of my stock speakers. Is it speakers' problem or head unit? I assume it's caused by speakers so if i am getting new set of speakers what brand should i get?? Thanks in advanced.
Old Oct 11, 2000 | 08:01 PM
mr tl's Avatar
Post
ive spent the last few days determining this problem!
its not worth it. youll have to change the speakers and amp. just put the treb/bass in the middle and fade it slightly to the back. that minimizes it
Old Oct 11, 2000 | 08:18 PM
Nate's Avatar
Post
Just turn the volume way, way up.
Old Oct 12, 2000 | 02:52 AM
Y2K_TL's Avatar
Post
Mr. TL
so you are basically telling me that there isn't a fix for this problem? if so then that sucks
Old Oct 12, 2000 | 07:59 AM
mr tl's Avatar
Post
yeah man. ohh, a new head unit should fix everything. but a decent one costs soo damn much! yeah, just leave it. thats what ive decided to do
Old Oct 12, 2000 | 08:04 AM
StreetEffectz's Avatar
Post
Although the factory speakers leave something to be desired, they are not the problem. The problem lies within the factory amp. I can tell you that adding an aftermarket amp with a little more power should clear up the hissing issue. I don't like the idea of amping factory speakers, BUT, never the less, this should correct the problem.
Old Oct 12, 2000 | 08:18 AM
Y2K_TL's Avatar
Post
StreetEffectz:
Why isn't it such a good idea??
amp=speaker?? or they are 2 different things
Old Oct 12, 2000 | 08:48 AM
Post
Couple of reasons....the factory speakers are just crappy paper cone speakers and too much power to them will blow them out. On top of that, they are only 1ohm...not really a standard in car audio. I just say replace the factory speakers and get a new amp.
Old Oct 12, 2000 | 01:12 PM
Post
You can run an aftermarket amp off the factory head unit with a "line converter". If you do want an aftermarket headunit thats decent and not too expensive, pioneer premier series may be good for you. I carry most lines of audio, so if you see something you like, let me know via email and I will give you a price.
Old Oct 12, 2000 | 01:23 PM
Nate's Avatar
Post
If your headunit has a higher pre-out you'll have more voltage through the RCAs and hopefully less interference.
Old Oct 12, 2000 | 11:34 PM
Y2K_TL's Avatar
Post
One more Q
new amp= new head unit??
anyhow what brand do you recommand?? something decent but not too expensive. thanks for all your help
Old Oct 24, 2000 | 09:35 AM
Guest
Guest
Posts: n/a
Talking
Streeteffectz,
Do I need 5.25 or 6.5 for my front in my CL-S? The rears are 6 x 9 right? Also, do you have any info on how deep a speaker I can fit in? Thanks..
AndrewS
19
Mar 14, 2024 06:59 PM
Feb 25, 2020 09:57 AM
iCrap
Sep 11, 2015 06:21 PM
alan_rich
Sep 7, 2015 11:08 PM
iRaw
ILX
Sep 5, 2015 12:10 AM
