CL: thats my first audio so i need lil help
i got this amp alpine MRD-M501 and im looking to buy some subwoofer with enclosure and i think i found one but i need your advice guys what do you think
link to my amp
http://www.crutchfield.com/S-417vOuR...-MRD-M501.html
and sub with enclosure
http://cgi.ebay.com/Alpine-Type-R-12...d=p3286.c0.m14
and also i need to help how to put everything togheter where get the signal to amp and etc what to use... do i need fuse or better look for 2 ohms subs or 4 ohms or something that is in your mind that would help me...
thanks from the begining
link to my amp
This... More cone area, and better sq. I've been nothing but dissapointed with the few type ARgh's I've heard... They sound terrible IMO, but I have to admit, they are pretty loud...
what about these ?
http://cgi.ebay.com/ebaymotors/ws/eB...STRK:MESELX:IT
They're alright... Like I said though, 2 E8's in a realitively small ported box tuned nice and low... That'll be a winner, and you'll be able to get the most out of your amp. Plus Woofercooker on ca.com is (or was at least) selling E8's for like $55 each or something crazy cheap like that. And he's in NY so cheaper shipping...
3.7L Nitrous Breathing CL
I'm pretty sure this is the same one I have.It's only 15-16 bucks shipped.I have used others but this is the only one thats held up so far and I was running 2 1600wrms amps from it no problems.
http://cgi.ebay.com/NEW-AXXESS-ALOC6...d=p3286.c0.m14
DEI info:
| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|white |+ |ignition harness |
| STARTER|black/white |+ |ignition harness |
| IGNITION|black/yellow |+ |ignition harness |
| ACCESSORY|yellow |+ |ignition harness |
| POWER LOCK|black/blue |- |passenger fuse box *1 |
| POWER UNLOCK|orange |- |passenger fuse box *1 |
| LOCK MOTOR|white/red | |drivers fuse box *2 |
| UNLOCK MOTOR|yellow | |drivers fuse box *2 |
| DISARM DEFEAT|lt. green/red | |passenger MUX module *3 |
| PARKING LIGHTS +|red/black | |passenger kick panel |
| PARKING LIGHTS -|red/yellow | |left of steering column |
| HEADLIGHTS|blue/red |- |left of steering column |
| DOOR TRIGGER|black/white |- |passenger fuse box |
| DOME SUPERVISION|use door trigger | | |
| TRUNK/HATCH PIN|blue/green |- |drivers fuse box |
| HOOD PIN|yellow |- |passenger fuse box |
|TRNK/HTCH RELEASE|white |+ |passenger MUX module *3 |
| FCTRY ALARM ARM|arms with lock | | |
|FCTRY ALRM DISARM|disarms with unlock | | |
| DISARM NO UNLOCK|blue |- |drivers door key cylinder |
| TACHOMETER|blue | |drivers shock tower *4 |
| SPEED SENSE|blue/white | |cruise control module *5 |
| BRAKE WIRE|white/black |+ |brake switch |
| HORN TRIGGER|lt. green/blue |- |steering column |
| WIPERS|blue & blue/yellow |- |left of steering column |
| LF WINDOW UP/DN|red/blu - red/yel |A |drivers window switch |
| RF WINDOW UP/DN|blu/yel - blu/wht |A |RF window switch |
| SUN RF OPN/CLOSE|grn/yel - grn/red |A |relays left of fuse box |
| RADIO 12V|white/yellow |+ |radio |
| RADIO GROUND|black |- |radio |
| RADIO SWITCH|white/red |+ |radio |
| RADIO ILLUMINATE|red/black |+ |radio |
| LF SPEAKER|blu/grn - gry/blk | |at speaker |
| RF SPEAKER|red/grn - brn/blk | |at speaker |
| LR SPEAKER|blu/yel - gry/wht | |at speaker |
| RR SPEAKER|red/yel - brn/wht | |at speaker |
Heres a list of some of our cars wirring.
Althou not the correct spot,I have mine from my cig lighter. Its ignition switched.When the cars on,the amps are on.
If you tap off the HU for a remote switch then amplifiers will turn on and off with the HU.
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
