TECH. QUESTION: Head Unit Output?
Old Aug 10, 2004 | 09:10 AM
garpt's Avatar
Hi all,
My first post on this board..been lurking since I bought my '04 TSX three weeks ago. Since then, added a nice DVD system. Now it's time to upgrade the stereo. My important tech. question: Is the OUTPUT from the HEAD UNIT (before it goes into the amp) a LOW LEVEL signal that will properly match the input of an aftermarket amp? I don't want to use Line Output Converters, as they are a compromise in sound quality (in my experience). Thanks for your help. Enjoy my new ride and this forum.
GARY
Old Aug 10, 2004 | 10:12 AM
elduderino's Avatar
VP Electricity
Yes, the stereo has F and R full-range outputs capable of ~900 mV output using the sine wave on the Alpine CAN test disc (the same output as my old Alpine 7904 CD player).
There is absolutely no need to use an Line Output Converter of any kind. A line driver might be useful- both amp upgrades I have done have been noise-free as long as the amp was set to minimum gain sensitivity, but you could hear a bit o noise once you nudged up the gain. I have a JL 300/4 and I have enough volume, but I still plan to test some line drivers.
Metra is considering makin an adapter for this... you might ind the poll thread asking abou this. Or call Metra in FL and tell them you want one - maybe you'll be the beta.
Can't believe I'm on this forum on the honeymoon...: )
(She's in the shower...)
Old Aug 10, 2004 | 10:38 AM
jiggaman's Avatar
I spend 2 much time here
What kind of adapters are you talking about eldurino?
Old Aug 10, 2004 | 12:23 PM
garpt's Avatar
Thanks, Elduderino. Right to the point. I've been reading some conflicting stuff here. If I remember right from my installation days, 1volt or a bit more is preferable, so I can see where a line driver MAY be helpful, but I'm hoping not needed. Thanks again. GARY
Old Aug 10, 2004 | 01:22 PM
x911gt2's Avatar
Anyone have any specifics on a good line driver and what kind of specs to look for?
Old Aug 10, 2004 | 01:37 PM
jiggaman's Avatar
without a line driver my system sounded like butt.
Old Aug 10, 2004 | 01:39 PM
x911gt2's Avatar
what line driver are you using?
Old Aug 11, 2004 | 08:28 PM
elduderino's Avatar
VP Electricity
Yes, there have been many conflicting posts on this topic. I've done two TSX installs with no LOCs.
My system sounds great w/o a line driver. The Phoenix Gold PLD 22 or 66 seem good.
J, I'm talking about plug-in harnesses in place of the factory amp, with RCA out for the amp, and the remote turn-on wire.
g, remember that the Alpine 7904 was rated to 2V by Alpine. It all depends on the test track you're using... with a "hotter" test track I could easily reach higher voltages. I think this track was -10dB but I forget... This was simply intended to show that the TSX head is capable of exactly the same output as a pre-"4V" high-end CD player.
Old Aug 13, 2004 | 11:58 AM
x911gt2's Avatar
Would the TLD66 be useful in boosting the output of an XM install as well as the amp signal?
Old Aug 13, 2004 | 12:03 PM
jiggaman's Avatar
you don't have any clipping coming from your tweeters?
i wonder why mine did without a line driver...either way i like line drivers because your amps gains don't need to be turned up as much.
Old Aug 13, 2004 | 12:07 PM
tuan209's Avatar
depends.....if you have noise coming from the HU a line driver wont help, adding a line driver and the source of noise is the HU , you will just amplify the noise. if the source of noise is coming in from the wires a line driver will help, so i suspect that your noise wasnt coming from the HU in the first place.
Old Aug 13, 2004 | 12:54 PM
joerockt's Avatar
Just dial 1911
Well, I can tell you that when Eld and I did my TSX, when we connected the line driver to the HU, turned down the gains on the amp and the noise went away. But, it sounded like azz. Of course the noise was probably still there, just not audable. Im still waiting on a good line driver as no one seems to have decent ones in stock. And every friggin ebay auction I've tried I keep getting outbid
Old Aug 15, 2004 | 10:27 PM
elduderino's Avatar
VP Electricity
While I am glad that jiggaman's system sounds better, his problem has never sounded like a line-driver-problem to me either... but I'm glad it sounds better... : )
Old Aug 16, 2004 | 06:10 AM
jiggaman's Avatar
it sounded clear as day after installing the line drivers. the installer said my highs were clipping.
Old Aug 16, 2004 | 09:34 AM
elduderino's Avatar
VP Electricity
Right. And that statement is typical of car stereo installers, unfortunately.
We know that the output of the head unit at full volume doesn't clip (that is, run out of output and chop the top off of the waveform due to lack of voltage) on a number of different amps.
We know that you had the gains on the amp UP before the line drivers, and turned down afterwards.
It's possible that he had your amp input gain sensitivity turned up too high, and the amp connected to your highs was clipping due to being maladjusted. He could have fixed that by turning it down. You may have lost too much volume by turning it down, and maybe that's the reason for the line drivers... in other words, the line driver may have fixed a problem that was caused by the real solution to your distortion problem - turning down the amp gain.
Old Aug 16, 2004 | 02:16 PM
jiggaman's Avatar
it wasn't a distortion sound. i wish you could have checked it out yourself. it was very strange. it was a crackling sound that only came from the right front tweeter. it happened with the stock speakers after i replaced the stock amp and it happened with my MB Quart components.
Jul 16, 2017 07:33 AM
Matthew Purpura
Sep 25, 2015 06:10 PM
Eggs999bacon
Sep 24, 2015 10:08 AM
rboller
Sep 23, 2015 02:49 PM
