Tapping into the rear 6x9s for LOC
Doesn't Rice His Car
1 Post
I know there are several ways to do it, but I'm curious, how did you guys do it? Did you ghetto rig it as in cut the wire, then use a "barrel connector" or soldering to patch it up? Or I was thinking maybe connecting it directly to the metal on the speakers with a connector (pictured below). Will polarity matter?
![](http://i98.photobucket.com/albums/l257/studville/speaker.jpg)
![](http://i98.photobucket.com/albums/l257/studville/connector.jpg)
Also I'm curious, where did you connect your remote wire for your amp. Concensus says in the console cig lighter. And did you just solder it in or what?
VP Electricity
1 Post
It looks like a TSX.
Relative polarity is crucial. Absolute polarity is not.
If you get one backwards relative to the other, your subs will have no bass.
Actually, smartypants, in the ghetto uninsulated wires are twisted onto the speaker terminals.
Butt connectors are not ghetto. They are functional and work well when quality connectors are properly used.
But it's cool if you don't like them.
If you don't want to use them, I would use heat shrink and solder on the wires on the harness.
If you are anal enough to solder wires onto the speaker terminals, you better be anal enough to add another set of disconnects too (serviceability, you know).
1 Post
I totally forgot that this forum is univeral and not TSX specific. (It's a 06 TSX/ NAV). On another note, I use the butt/barrel connectors all the time. I was in a hurry and actually meant by ghetto rigging as in twisting the wires together and taping em up with electrical tape.
Anyhow, thanks for the replies. What do you guys think about clipping onto the metal with the connector pictured there?
Also I'm trying to take out the console so I can run my remote wire (cig lighter in console). The thing won't budge. Any tips. I read somewhere that there was also a switchable 12v coming into the factory amp (green w/ a strip or something.. I'd use a voltmeter of course). I have no clue where that is though.
1 Post
Originally Posted by Landocommando12
What is LOC? Just wonderin what you're doin here. I've never tapped into my rear speaker for anything when hooking up my stereo.
And I found the instructions on removing the console here
http://andylee.us/gallery/console/IMG_1033
(thanks Arcticcl9)
Just now debating on whether or not to tap into cig lighter or factory amp (wherever that is) for the remote... and if I should use the connector pictured on post #1 to tap into the 6x9s
09-17-2015 09:01 PM
09-14-2015 10:48 AM
alan_rich
09-07-2015 11:08 PM
