system question
Old Oct 7, 2001 | 11:23 PM
indy-on tl's Avatar
system question
Do you guys think that a set up, which includes two eclipse aluminum 12 inch subs, and 2 rockford fosgate 800a2 amps. Can work well together to perform at their best being used in a 1999 TL. clarity, power, and sound wise.
And what type of install i could get for six hundred dollars with this installed
Old Oct 20, 2001 | 09:16 AM
Tripnbeats's Avatar
honestly
For 600 dollars u can get a nice install done. also consider interior speakers because those subs overide A LOT they r no joke and I'm sure u know that by now. Check also if ur amps are 2 ohm stable because i think the subs r. if they r rig it like that because then the amps will push those things like u would even imagine. i built a box for a 97 prelude and hooked up a 1400Watt PPI amp to them, if i tweaked the bass a little more or added another sub I'm sure the window could have shattered those subs were pushing out 172 db. consider sound proofing for the trunk.
Feb 25, 2020 09:57 AM
heykosal
1G RDX Problems & Fixes
Sep 21, 2015 09:41 AM
datadr
Sep 12, 2015 09:12 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
