system completed! one problem...
Old Mar 17, 2002 | 07:29 PM
jz983's Avatar
hey. i have a RF punch 400.4 (x4) running my speakers and a rf punch 500X (x2) running my dvc sub. after the distribution block, there is a 1 farad cap. i hooked everything up right. now my speakers work just great. my sub doesn't though. i don't know what it could be. the amp LED is lit, it is getting power (is a brand new amp). could there be something wrong with the capacitor? here is how i connected the cap . there are 2 connections on the positiver terminal of the cap, the power from battery and the power to the amp. there are 2 connections on the negative terminal, one grounding the cap itself and the other is the negative wire from the amp. i heard you can do this so...w
well i need help. i don't know whats wrong with the subwoofer side of my system. i can explain more if you need....
Old Mar 17, 2002 | 08:05 PM
96TL's Avatar
Ex-Mod
If the LED on the amp is on, then your cap shouldnt be the problem. Check the RCA cables. Switch the RCAs from the 400.4 to the 500x and see if the subs work. If not, then make sure the speaker wires are hooked up right.
Old Mar 17, 2002 | 08:33 PM
jz983's Avatar
im just worried about not charging the cap right. you know how youshould charge it with the resistor the very first time you use it? well i don't know if i did it right. but i don't think that is the problem... *** sh*t!
Old Mar 17, 2002 | 08:55 PM
96TL's Avatar
Ex-Mod
Did you switch the RCAs like I said?
Old Mar 17, 2002 | 09:01 PM
jz983's Avatar
not yet man. i need to do that later, i have some work to do now.
i'll keep you posted.
thanks
Old Mar 18, 2002 | 06:45 PM
jz983's Avatar
everything is fine! the rca colors were reversed. stupid me!
Old Mar 18, 2002 | 06:53 PM
96TL's Avatar
Ex-Mod
Hehe. I told you it was the RCAs.
Old Mar 21, 2002 | 02:41 AM
Austin519's Avatar
jz983:
Yah...and about charging the cap...you don't really have to charge it with a resistor...that's just so you don't spark and melt things. I have yet to actually do that...takes to damn long...I'm all about the spark and melt method.
96TL:
Wow you go boy
Austin519
Old Mar 21, 2002 | 08:10 AM
96TL's Avatar
Ex-Mod
Originally posted by Austin519
96TL:
Wow you go boy
Austin519
Feb 25, 2020 09:57 AM
ExcelerateRep
Dec 11, 2015 12:58 PM
Sep 17, 2015 09:01 PM
Sep 15, 2015 06:44 PM
Sep 14, 2015 10:09 PM
