Subwoofer wiring...(Quick question)
Old Sep 2, 2004 | 09:57 PM
J.T.'s 3.2CL's Avatar
Has been sold for a while
I am installing two Kicker Comp VR dual 4 ohm 12" subs in my neighbors car tomorrow and I want to be sure I wired them correctly. I am trying to achieve a 4 ohm load to the amp. This is a chart of what I'm trying to do:
2 DVC drivers with Voice Coils in Series / Parallel
Connecting the two voice coils of each driver in series (+ to -) and the drivers themselves in parallel (+ to +, etc.) will result in the following impedances:
Dual-6 Ohm Subwoofers: 6 Ohms
Dual-4 Ohm Subwoofer: 4 Ohms
Dual-2 Ohm Subwoofer: 2 Ohms
This is a pic of the actual sub wiring. I assume the pole connectors with the white dots represent one voice coil? That is the part that confuses me. Is the picture wired correctly so far? To finish the wiring would I need to connect the two remaining positives together and the two remaining negatives together?
Old Sep 3, 2004 | 08:38 AM
phipark's Avatar
Not Asian
Each dot represents the positive terminal of each voice coil.
Old Sep 3, 2004 | 06:06 PM
donduncan's Avatar
go go go go go
wiring subwoofers
to get 4 ohms load, you have to wiring each speaker to be 2 ohms(use jumper wire hook both + sides together, then - sides together) on each speaker. Instead of 4 wires coming from each speaker you should have 2 by wiring in parallel. Then you hook the 2 wires from each speaker in a series configuration. Join the + wire on one woofer to the - wire on the second woofer, then the remaining +and- wires to the amp. That will get you 4 ohms load.
Don
BoricuaTL
Apr 8, 2016 01:08 PM
Rdub81
ILX Photograph Gallery
Mar 17, 2016 03:02 PM
Strath
Sep 27, 2015 11:53 PM
HOWELLiNC
Sep 20, 2015 04:21 PM
datadr
Sep 12, 2015 09:12 PM
