Subwoofer frequency!
I'm looking to get the Pioneer TS-W254F, a 10" Free Air Sub. I noticed that the frequency response is 18 - 2500Hz. Is it high because its a free air or does this mean it's not a true bass? Will such a wide range in frequency prevent a nice deep thump?
Thanks!!
-Rich
Thanks!!
-Rich
1 Post
Are you sure it wasn't 250hz? You should definately use a crossover, I usually cross my subs at 200-250hz. A free air sub usually doesnt hit as low or as hard as a sealed or ported box, but they are designed to sound good, so if you want a deep hard bass, free air is not the way to go.
Chris
Chris
Chris
Chris
Don't worry about what a sub goes up to because you would use a crossover to cut the frequencies above 70-90Hz. By the way, most good 12" to 15" subs don't go down to 18Hz reliably so I wouldn't put much faith in Pioneer's numbers.
I agree with you on replacing the factory sub and amp. Do a search for the Kicker RMB8 as it has been pretty popular as a direct replacement. DrCookie was the first to do this mod and is the father of the RMB8 stock replacement.
There is actually a very recent post about randomwalk101 installing the RMB8. By the way, I have one for sale for $80 plus shipping. I bought my pair from Sounddomain.com.
Other alternatives that are low profile and will fit without removing the torsion bars include the Illusion Audio ND8 and Morel speakers.
David
David
David
David
Rmarin2
I know what you are saying about the RMB8 since I bought it to be a midbass driver to go in my doors. However, it can also go fairly low and play like a sub although it is most efficient as a midbass driver. It is obvious to me that the Pioneer specs are inaccurate. Therefore, I would have a difficult time trusting the Pioneer. See my post to you in **********.com for more reasons I don't believe in their specs.
There are other freeair low-profile speakers to look at including Morel, Illusion Audio, DEI, and Blaupunkt. Unfortunately, most of these are somewhat expensive.
There was one person on this forum that I remember seeing use a Pioneer freeair driver. I would ask that person their opinion of the Pioneer freeair.
Going back to your original question. You would use a crossover, preferably adjustable to remove those high frequencies from the sub. The higher the sub plays, the more localized you will hear it. If you have a sub play below 80, you shouldn't be able to identify where it is coming from due to the frequency wavelength. However, above 80Hz, the sub will start to become localized and you will be able to tell it is playing from the back. An adjustable crossover allows you to dial in the sub where it plays smoothly with the front speakers.
Check some other forums for product advice such as Elitecaraudio.com, carsound.com, and sounddomain.com.
David
David
kb1rl
09-30-2015 10:17 AM
4drviper
09-23-2015 09:00 PM
3GTLOwns
09-09-2015 09:51 PM
