Subs and AMps
Old Apr 19, 2005 | 06:39 PM
cArKc's Avatar
crc
Subs and AMps
i have 2 12" image dynamics IDQ serise. it says the reconmended power is 350 each. right now they i have 2 jl e1200 amps ruinnig them which means 200 watts per sub. would you guys think it would make a noticble difference if i purchased the MTX Audio Thunder801D which will give it each about 400 watts. read some reviews on the amp and it seems to be a pretty good amp for the price. what do you guys think?
Old Apr 19, 2005 | 10:38 PM
DerrickM's Avatar
I have an 801D running my Infinity 12.1 sub, and I'm happy with it. Don't know how that would compare to the e1200.
BUT, I will say that I switched for the same reason--I had a 200w amp (at 4 ohms, Rockford), and it wasn't powerful enough, so I went with the 801d, which is 400 watts at 4 ohms.
Old Apr 19, 2005 | 11:38 PM
cArKc's Avatar
crc
was the change noticeable? did the subs sound a lot louder or clearer? and the 801d is 800watts rms (countinuos) with 2 ohms right?
Old Apr 20, 2005 | 12:16 AM
DerrickM's Avatar
Very noticable. Yep, same amp. I'm pushing a single Infinity "Perfect 12.1" sub in a 1.0 cf sealed enclosure.
Old Apr 20, 2005 | 12:23 AM
DerrickM's Avatar
Your mailbox is full, so I was not able to reply to your last PM. My response was:
I believe the specs--I've been a fan of MTX for years. This is my third MTX amp. (My main is a 564, and my last car had a 4160). Many people would recommend much higher-end amps, but for me MTX has the right performance/value mix.
Are your subs sealed or ported? I'm sure it'll be fine either way, but ported would give you more volume. Just make sure the boxes are the right size for the subs.
Old Apr 20, 2005 | 12:27 AM
cArKc's Avatar
crc
box are seald
Old Apr 22, 2005 | 04:03 AM
vidoprof's Avatar
Double power, which is what you are talking about here and you will get a 3db increase in sound. Which is noticeable.. It will sound much better.. of course this is IF this is CLEAN power going to those subs..
MOST subs, including your Image Dynamics are totally fine with playing above RMS.
Ryan
Old Apr 22, 2005 | 05:19 PM
cArKc's Avatar
crc
alright, thanks a lot
4drviper
Apr 23, 2025 07:13 PM
Jul 16, 2017 07:33 AM
InFaMouSLink
Oct 30, 2015 09:43 AM
kb1rl
Sep 30, 2015 10:17 AM
