TL: sub setup help
Old Jul 6, 2009 | 06:04 AM
xplicitzTL's Avatar
sub setup help
i have the 2000 acura tl with all the trunk space and about 700usd to spend... is that enough? i would rather take as minimal space as possible since i go on trips a lot like camping. i saw someones setup and it just took the space off the side. the box had to be customized and it looked madd clean... any opinion is welcome and thanks for this site!!!
Old Jul 6, 2009 | 10:08 AM
D.Greenwood13's Avatar
2000 WDP
how loud u wanting to go?
Old Jul 6, 2009 | 11:49 AM
xplicitzTL's Avatar
loud enough for the next car to hear my music but not as loud as the next block singing to my tunes. lol
Old Jul 6, 2009 | 12:18 PM
'03TL-S's Avatar
if you want a setup to the side, i think you'd have to fiberglass it. Uncald4 does amazing work with his fiberglass setups but they get pretty expensive. For that amount of money, you can get a good sub+amp combo that can get pretty loud.
Old Jul 6, 2009 | 12:33 PM
2000 WDP
Do a single 10" in a ported box tuned down to 28-30 hz if the sub can handle it. I like the Diamond D3 10"s and theyre a damn good sub for the sound/price, weve sold many at the shop and all were happy with them!!
Old Jul 6, 2009 | 01:35 PM
xplicitzTL's Avatar
what kind of amp should i look for.... im not really familiar with how it works.... lol
Old Jul 6, 2009 | 01:40 PM
2000 WDP
If u get the Diamond D3 10", get the dual 4 ohm model and either the Diamond D1 400.1 or the D3 600.1 amp
Old Jul 6, 2009 | 07:29 PM
xplicitzTL's Avatar
im just guessing that the d3 600.1 is a higher model and better wattage = louder music?
Old Jul 6, 2009 | 07:35 PM
mattastick's Avatar
That's install dependent... I know of a Blazer that did over 160 db legal on a TL meter in competition on only like 1kw, but yet I've personally never done better than a 138.8db with 1200w... That blazer was an extreme class car with concrete everywhere and 3" thick glass, whereas my car was built for Street A and 0 deadener of any kind... Like I said, it's all install dependent. But, if you were to do a drop in test with the exact same setup, you should get louder by upping the power. This is assuming you have the electrical upgrades to support the up in power...
Old Jul 6, 2009 | 08:03 PM
2000 WDP
The 400.1 is 400 watts RMS @ 2 ohms and the the 600.1 is also 400 watts RMS @ 2 ohms but it also goes down to a 1 ohm load and puts out 600 watts RMS which is good incase u ever decide to get another sub. Also, its better to have more power and have the gain down than have less power and have the gain all the way up.
Old Jul 6, 2009 | 08:08 PM
on1wheel01's Avatar
man u love those diamonds dont u lol. u suggest u go to a car audio web site and do some reading. caraudio.com/forum is a good one. or go here http://www.caraudioclassifieds.org/f...eferrerid=1202 . Are you looking for new or used. For 700 and buying used you can slam with the killerness. I'd say a sundown saz1500 with maybe a 10" re audio dd audio fi audio bl or q, aq sub. or what not. the saz1500 will run you about 250-325 shipped. and it is 1500 rms not max. If i remember right someone on here has one for sale if i remember right.. ahhhhhum....
Old Jul 6, 2009 | 08:09 PM
on1wheel01's Avatar
And remember you ususally dont blow subs from to much power but rather from under distorted dirty skanky ho power. Get a good amp and set the gains with a multi meter.
Old Jul 6, 2009 | 08:28 PM
eggyhustles's Avatar
dd 1508, ported box tuned high (36-39hz)
Old Jul 6, 2009 | 08:32 PM
2000 WDP
[quote=on1wheel01;11078484]man u love those diamonds dont u lol....quote]
Lol sure do bro, its 1 of the main lines we carry at the shop & weve never had 1 return with them, and if theyre installed by a Diamond retailer they have a 3 year warranty instead of just 1. Jermaine Taylors Phantom had all Alpine Type X and we switched it all to Diamond and sounded worlds better!! Check out our website in my signature and see sum of the work we've done with them.
Old Jul 6, 2009 | 08:52 PM
mattastick's Avatar
OP, how much space are you willing to give up in your trunk? The more space you're willing to give up (generally) will determine how loud you're going to be able to get...
Old Jul 6, 2009 | 08:56 PM
2000 WDP
He said as little as possible, and he liked Uncald4's boxes so i guess not that much so hes not gonna go too loud
Old Jul 7, 2009 | 08:50 AM
xplicitzTL's Avatar
wow thanks for the replies... i just need one sub and im not trying to compete with anyone. i guess i just want something to blow me away not others. so i guess ill go check other forums and learn more about it before i start buying something. I will get the uncald4's trunk box and see how that works. i am actually debating between diamond and JL ill probably get the 600.1 diamond amp
Old Jul 7, 2009 | 09:31 AM
2000 WDP
No prob man, id get the Diamond, JL has good stuff but way overpriced.
Old Jul 7, 2009 | 09:53 AM
mattastick's Avatar
This, but I'd tune at 32hz.
Old Jul 7, 2009 | 11:26 AM
xplicitzTL's Avatar
do i need a multi channel amp? As far as i know i need amp for the subs right? and more power means louder? i was considering diamond 600.1 and maybe either the dd or the diamond d3
Old Jul 7, 2009 | 11:32 AM
mattastick's Avatar
How many channels you need is determined by what you're wanting to power. If you want to add a set of components, you could pick up an MB Quart Discuss 4125 and bridge the rear channels to a sub, and use the front channels to power a nice set of comps. If you only want to power the sub, a small monoblock or 2 channel amp would work. It's all up to you and how far you're going to take the install...
Old Jul 7, 2009 | 11:36 AM
xplicitzTL's Avatar
so if im using stock speakers and radio i dont need a multi channel? but if im planning to get better ones in the future ill be better of wit a multi then right? but for now its only for the subs since im sticking wit stock bose. im basically just adding subs for now and maybe slowly get better radio, speakers and tweeters
xplicitzTL's Avatar
im sorry bout all the questions this is the 1st time im encountering this... i know a lot bout kicks and comps but cars im a noob lol
Old Jul 7, 2009 | 12:00 PM
mattastick's Avatar
Basically... With that $700 you're talking about spending, you should be able to get a decent to good set of components (better if you don't mind buying used), new hu (again same thing as the comps), amp, sub, install gear, etc. I think when I priced out everything for my buddy's truck, I had new hu, comps, amp, subs (2 8's), wire, boxes, etc. for about $750-800. If you don't mind putting in the work, you can get more for your money... If you want to buy everything or pay someone to do it, you're not going to get as much... BTW, where are you located?
Old Jul 7, 2009 | 12:02 PM
xplicitzTL's Avatar
i am in NYC
Old Jul 7, 2009 | 12:03 PM
2000 WDP
All u need right now is a mono-block or a 2 channel and bridge it, and when u update your mids/highs get u a 4 channel amp. Or like Matt was sayin get a decent 4 channel and bridge the rear for the sub and use the other for front speakers. & yea if u plan on getting someone to install it all thats gonna eat up a lil chunk of it too.
Old Jul 7, 2009 | 12:06 PM
xplicitzTL's Avatar
i guess ill have to look into DYI or find a buddy who i can get cases of heineys
Old Jul 7, 2009 | 12:08 PM
mattastick's Avatar
i am in NYC
Sucks you aren't closer, or I'd help you with the install...
Old Jul 7, 2009 | 12:19 PM
xplicitzTL's Avatar
thanks matt... maybe ill drive to u haha
Old Jul 7, 2009 | 12:27 PM
mattastick's Avatar
Works for me... Just give me a heads up as to when you're coming down...
Old Jul 7, 2009 | 03:52 PM
2000 WDP
Post sum pix when u get it all in
Old Jul 7, 2009 | 04:13 PM
xplicitzTL's Avatar
i will as soon as possible thanx
Old Jul 7, 2009 | 07:02 PM
from what i noticed, they get a lil sloppy tuned that low
Old Jul 7, 2009 | 08:03 PM
goMO's Avatar
hey - I was going to drive out to have Matt help me out - get in line!!!!
Old Jul 7, 2009 | 08:42 PM
xplicitzTL's Avatar
haha maybe we can go together since ur in NJ and im in NY lol
Old Jul 7, 2009 | 08:43 PM
mattastick's Avatar
Have you tuned them that low and heard it in person? I haven't, but from what I've heard from 1st hand accounts, the 1508's will play well when tuned at 32hz, whereas the other, larger DD's will not. Most of the other DD's like the higher (38-40hz) tuning, but from what I've heard from people that've done it, the 1508 and most if not all AQ subs will do well when tuned at 32hz.
Old Jul 7, 2009 | 08:45 PM
mattastick's Avatar
Whatever works guys, I'm always down for helping with some installs... Just let me know when you're on the way, and what needs to be done...
Jul 16, 2017 07:33 AM
yesSIR-S
May 13, 2016 05:42 PM
dirleton
Sep 25, 2015 12:25 AM
Sep 17, 2015 09:01 PM
