sub and plexiglass question
Old Aug 19, 2006 | 01:37 AM
socal01cls's Avatar
7th Gear
I want to design a system just like this:
http://www.alphaaudio.com/installs/ImpalaSS.html
except with black carpet, flush trunk floor with plexiglass with amps under it, and acura symbol instead of the impala.
But does covering the front of the subs with a panel with plexiglass affect the quality of sound?
The box i am using is sealed box and the plexiglass will just be sitting in front of the subs.
Old Aug 19, 2006 | 08:43 AM
phipark's Avatar
Not Asian
Yes, covering the sub with anything can change the sound or SPL.
Old Aug 19, 2006 | 01:27 PM
socal01cls's Avatar
7th Gear
what about mounting the subs on plexiglass with a MDF enclosure like this?
http://www.carstereo.com/installs/ph...w=1&maxrows=12
Also, i want to make my trunk usable so should i worry about stuff( shoes, food, etc) hitting the subs? could it possibly damage the subs?
Old Aug 19, 2006 | 10:40 PM
Spoon's Avatar
Seems to me from those pics that the subs are sealed off from the trunk but essentially fire thu the rear deck, it's basically as if they are in the cabin, so it should sound pretty damn good. But, just putting plexiglass over the sub would not be a good idea if you were to seal the plexiglass to the enclosure.
Old Aug 20, 2006 | 04:35 PM
socal01cls's Avatar
7th Gear
then that would basically be a band pass right?
i am just planning to use the plexiglass to act as a loading board. I heard that this helps reduce trunk noise by the sound bouncing off the plexiglass instead of the trunk.
Old Aug 21, 2006 | 01:23 AM
victorvu's Avatar
well it also depends on what subs you're using. some subs sound better in a sealed box and some sound better in a band pass. but it wouldnt be a good idea to cover it in plexiglass as all of the other guys have said. if you're looking to stop noise use dynomat.
Old Aug 22, 2006 | 03:24 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
That's a bandpass to the rear deck
ttimberlak443
21
Oct 22, 2016 10:23 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
