sub addition
Old Dec 24, 2003 | 08:28 AM
KJLite's Avatar
sub addition
sorry for the repost, but people seem to be glossing over my previous post
so i think i am going to eventually add a sub. i think the stock 6x9s are great, but i'm spoiled with my 12" sub at home. the problem is i don't have the desire nor money to put some flashy install in. i also don't want to eat up my trunk space with a massive sub box.
i was thinking of buying an amplifed sub. they claim you can tap the signal off another speaker. the rear deck 6x9s are sitting right there. i realize the sound quality will be less, but it is a sub, so clarity is not as important.
anyone have any experience tapping the seaker level output to a sub?
Old Dec 24, 2003 | 11:26 AM
Dan Martin's Avatar
Photography Nerd
Re: sub addition
I've done it before and it wasn't bad. The only thing that can be a little annoying is that you can't adjust the volume of the sub from the drivers seat. You have to go into the trunk and adjust the line adapter so tweaking it to get just the right balance is a little time consuming.
I might be misreading your post but I'm not sure what the line adapter has anything to do with space in your trunk...
If you are concerned about space, I would make an adapter that lets you use two 8" subs where the 6x9's are.
Old Dec 28, 2003 | 02:30 PM
badboy6453's Avatar
running wires
hey i am adding subs to my car. was it hard taking everything apart and running the wires? the remote wire......what color wire did you hook it up to in the back of the radio. and how did you run the main power wire thru all that under the steering wheel?
baelim
May 10, 2018 09:53 AM
rcs86
Aug 2, 2016 06:52 PM
brboy
Oct 5, 2015 11:34 AM
jmaxima03
Sep 27, 2015 10:22 AM
