Stock sub alternative
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
Hi All
Has anybody considered using Kicker comp series or JL Audio IB4 series free air subs?
I know that lot of members in this forum choosing kicker RMB8 since its an "easy fit". But I also noticed member "rmarin2" successfully replacing stock sub with pioneer 10" free air sub.
So will it be allright if I decide to replace the stock sub with any one of the sub above?
And if you could, which one would u recomend?
Re: Stock sub alternative
Originally posted by ash3ktl
Hi All
Hi All
There really wasn't that much of a large selection of free air subs a few months ago when I was looking. I'm happy with the Pioneer, even though I had to modify the stock location to make it fit.
Good luck with your choice. If you need any more info feel free to drop a line!! rmarinls@nyc.rr.com
-Rich
Thx Rich
I was just wondering if anyone had used / knows abt the Kicker F' series/Comp series OR JL Audio IB4 series subs. They all are free air or can be used as free air. As far as the wattage is concerned, i think they have lower wattage than the pioneer sub. But as u know, the stock sub is 1ohm and the stock amp is 100w. So the wattage delivered to he pioneer sub in your case will be 100W/4ohm=25w. So wont the sub be underpowered? Does your sub enough "thump"?
i belive that any of those would be a good choice... but i am curious why no one has tried the illusion audio 10 free air.... i mean it is slim like the kicker but a true sub like the jl or pioneer..... but either way you go i would imagine that you would deffinately need an after market amp....
I'm having hard time finding Illusions. Does anybody know where to find them?
Also the morel hcw10 has a 2.91" mounting depth.
and try this http://www.gspr.com/blau/odwp_flat_subwoofers.html
Wonder how is it?
Wonder how is it?
Thx Rich
Thx Rich
Thats right! Stock sub is 9" and 10" sub fits with some modification. I know rmarin2 and t.diddy has successfully done it.
Here's the link
http://www.acura-tl.com/forum/showth...threadid=45542
rmarin2
Is it possible to remove the old amp and use the power and the line level sub signal to another amp? I really don't want to run cable from the battery. Thats little too much for me right now.
Here's the link
rmarin2
Here's the link
rmarin2
Here's the link
rmarin2
As for the line inputs, i tapped into the low inputs that run to the stock amp and ran it to my crossover and then outputted that signal into the amp.
Thx Rich
I guess u r right. Looks like I'll have to run wire thru the battery anyway. One more question.
Lets say I want to drive this Pioneer free air sub (4Ohms) using a 2-channel amp in bridged configuration. So now each amp channel will see the load of 2Ohms. Will it works without any problem?
What is the model number of the amp?
Bryan
Bryan
Originally posted by rmarin2
Well I'm not using the stock amp. I bypassed it and am using an old phoenix gold amp. I believe the amp is rated for at least 250W (it's really old model and can't find any info on it).
Thx Rich
Thx Rich
Bryan
Bryan
No other info on it.
here is some info on that amp
http://www.phoenixgold.com/webfaq/Sapphire.htm
hey what sub are you pushing with this amp
i am considering buying one from ebay for 60 bux
to push a jl audio 15w0 rated at 150wrms 4ohm
right now im using a punch 40.2 and ithink its only rated at 40wrms 4ohm bridged
and want a little more power
l8r
l8r
l8r
l8r
That amp is no longer in use. I've been using an MTX 302 which is rated at 300W RMS bridged w/ a 4ohm load. Im using a Pioneer 10" free-air sub with it. Check out sig or my website for more details.
-Rich
the power handling does not change. the coil is still going to handle as much power as the "non-freeair" brothers. only thing changes is the mechanical power handling, unless the company added a stiffer suspension or something.
as far a infinite-baffle subs go, there are many out there on the market.
RE XXX-series
Adire audio Brahma
Elemental design O-series
Image Dynamics IDMAX
Image Dynamics IDQ
JL audio W7
Kicker CompVR
etc...
A LOT more subs out there. depends how much you're willing to pay. out of those subs, the ED O-series is probably your best bet. sounds similar to the idmax in an IB setup. not to mention its only about $150+shipping. that a heck of a deal for a high quality sub. u don't regret it (as far as SQ and output). 17mm of xmax i believe. not too bad eh?
RE XXX-series
Adire audio Brahma
Image Dynamics IDQ
JL audio W7
Kicker CompVR
etc...
DerrickW
11-15-2015 05:52 PM
