Stock sub alternative
Old Sep 27, 2002 | 10:45 AM
Question Stock sub alternative
Hi All
Has anybody considered using Kicker comp series or JL Audio IB4 series free air subs?
I know that lot of members in this forum choosing kicker RMB8 since its an "easy fit". But I also noticed member "rmarin2" successfully replacing stock sub with pioneer 10" free air sub.
So will it be allright if I decide to replace the stock sub with any one of the sub above?
And if you could, which one would u recomend?
Old Sep 27, 2002 | 02:30 PM
rmarin2's Avatar
Re: Stock sub alternative
Originally posted by ash3ktl
Hi All
I think any sub you choose will be fine as long as you get a free air. I wanted something with a high RMS wattage as well as a true sub, not a mid-range. I think of all the subs I compared the Pioneer had the most power, 250W RMS @ 4-ohm. The only issue was that it has a broad freq response curve so I used a crossover at 80Hz to kill signals above that.
There really wasn't that much of a large selection of free air subs a few months ago when I was looking. I'm happy with the Pioneer, even though I had to modify the stock location to make it fit.
Good luck with your choice. If you need any more info feel free to drop a line!! rmarinls@nyc.rr.com
-Rich
Old Sep 28, 2002 | 01:29 PM
Thx Rich
I was just wondering if anyone had used / knows abt the Kicker F' series/Comp series OR JL Audio IB4 series subs. They all are free air or can be used as free air. As far as the wattage is concerned, i think they have lower wattage than the pioneer sub. But as u know, the stock sub is 1ohm and the stock amp is 100w. So the wattage delivered to he pioneer sub in your case will be 100W/4ohm=25w. So wont the sub be underpowered? Does your sub enough "thump"?
Old Sep 28, 2002 | 02:49 PM
shawhite's Avatar
i belive that any of those would be a good choice... but i am curious why no one has tried the illusion audio 10 free air.... i mean it is slim like the kicker but a true sub like the jl or pioneer..... but either way you go i would imagine that you would deffinately need an after market amp....
Old Sep 29, 2002 | 11:59 AM
I'm having hard time finding Illusions. Does anybody know where to find them?
Also the morel hcw10 has a 2.91" mounting depth.
and try this http://www.gspr.com/blau/odwp_flat_subwoofers.html
Wonder how is it?
Old Sep 29, 2002 | 02:07 PM
paultl's Avatar
stock set-up is 8" sub....
will a 10" fit?
Old Sep 29, 2002 | 08:02 PM
rmarin2's Avatar
will a 10" fit?
Stock sub is a 9". 10" will fit with modifications!
Old Sep 29, 2002 | 08:05 PM
rmarin2's Avatar
Thx Rich
Well I'm not using the stock amp. I bypassed it and am using an old phoenix gold amp. I believe the amp is rated for at least 250W (it's really old model and can't find any info on it).
Old Sep 29, 2002 | 08:13 PM
Thats right! Stock sub is 9" and 10" sub fits with some modification. I know rmarin2 and t.diddy has successfully done it.
Here's the link
http://www.acura-tl.com/forum/showth...threadid=45542
rmarin2
Is it possible to remove the old amp and use the power and the line level sub signal to another amp? I really don't want to run cable from the battery. Thats little too much for me right now.
Old Sep 30, 2002 | 08:10 PM
rmarin2's Avatar
Here's the link
rmarin2
Well I think its possible to use the power line that runs to the stock amp but I wouldn't recommend it. If you use that power and run it to a separate amp, its possible that the amp will draw more power than the wire can hold and end up causing the wire to burn, thus causing a fire. I highly recommend running at least 8 gauge wire from the battery to the new amp.
As for the line inputs, i tapped into the low inputs that run to the stock amp and ran it to my crossover and then outputted that signal into the amp.
Old Oct 1, 2002 | 10:26 AM
Thx Rich
I guess u r right. Looks like I'll have to run wire thru the battery anyway. One more question.
Lets say I want to drive this Pioneer free air sub (4Ohms) using a 2-channel amp in bridged configuration. So now each amp channel will see the load of 2Ohms. Will it works without any problem?
Old Oct 1, 2002 | 01:57 PM
autophile1's Avatar
What is the model number of the amp?
Bryan
Old Oct 3, 2002 | 12:25 PM
rmarin2's Avatar
Thx Rich
Well thats the config I'm using. Since there is only 1 channel for the low level sub inputs, I ran it to a crossover, boosted the signal and filter out signals above 80Hz and then ran that single channel to the new amp and out to the sub. So far I haven't had any problems. No hissing noises or what sounds like bad "juice". Although if I was to replace the amp with a better one I think the sound would be a tad cleaner.
Old Oct 3, 2002 | 12:30 PM
rmarin2's Avatar
Bryan
Well the only number I can find on it is "SA1.0x" 2-channel amp by Phoenix Gold.
No other info on it.
Old Oct 17, 2003 | 11:30 PM
backwerd's Avatar
here is some info on that amp
http://www.phoenixgold.com/webfaq/Sapphire.htm
hey what sub are you pushing with this amp
i am considering buying one from ebay for 60 bux
to push a jl audio 15w0 rated at 150wrms 4ohm
right now im using a punch 40.2 and ithink its only rated at 40wrms 4ohm bridged
and want a little more power
l8r
Old Oct 18, 2003 | 10:46 AM
rmarin2's Avatar
l8r
That amp is no longer in use. I've been using an MTX 302 which is rated at 300W RMS bridged w/ a 4ohm load. Im using a Pioneer 10" free-air sub with it. Check out sig or my website for more details.
-Rich
Old Oct 19, 2003 | 10:15 AM
GSteg's Avatar
the power handling does not change. the coil is still going to handle as much power as the "non-freeair" brothers. only thing changes is the mechanical power handling, unless the company added a stiffer suspension or something.
as far a infinite-baffle subs go, there are many out there on the market.
RE XXX-series
Adire audio Brahma
Elemental design O-series
Image Dynamics IDMAX
Image Dynamics IDQ
JL audio W7
Kicker CompVR
etc...
A LOT more subs out there. depends how much you're willing to pay. out of those subs, the ED O-series is probably your best bet. sounds similar to the idmax in an IB setup. not to mention its only about $150+shipping. that a heck of a deal for a high quality sub. u don't regret it (as far as SQ and output). 17mm of xmax i believe. not too bad eh?
Jul 16, 2017 07:33 AM
DerrickW
Nov 15, 2015 05:52 PM
brboy
Oct 5, 2015 11:34 AM
rangomango
California
Sep 24, 2015 05:47 PM
