stock amp access
Old Mar 14, 2003 | 06:32 PM
TL-IGHTS's Avatar
Registered Abuser
stock amp access
once ive lifted the rear seat up, how do i get to the stock amp? where is it? ive tried the search but it wont let me search for amp. please help..
thanks
matt
Old Mar 14, 2003 | 07:15 PM
rmarin2's Avatar
You have to remove the rear seat back in order to get to the amp. Once you do that you'll see a shiny metal box screwed onto the frame on the passenger side of the frame.
Here is a pic of when I replaced mine:
http://home.nyc.rr.com/tltypes/images/audio/sub1.jpg
You'll see the amp right on the passenger side.
Hope that helps.
-Rich
Old Mar 14, 2003 | 07:16 PM
shodawg124's Avatar
by "lifting the rear seat" do you mean the backrest section, or just the seat cushion? make sure you took out the whole backrest...
if you took the backrest off, you'll see a small rectangular metal box in the lower corner of the passenger side. that's the stock sub's amp. the wires you'll be tapping are there (remote on, and mono +&-)
read this post about drcookie's project, where he replaced the stock sub with an aftermarket free-air sub. there's alotta reading, but there's pictures in there which really help... especially when it comes time to run your power wire through the firewall:
http://www.acura-tl.com/forum/showth...threadid=37582
good luck!
Old Mar 16, 2003 | 01:11 AM
bozzchem's Avatar
Why do you want to get to the stock "amp"?
I have amp in quotes because calling it an amp is questionable. Don't plan to use it for upgrades. It is a proprietary piece from Blose.
Don't think of it as a typical aftermarket amp...it's NOT.
4drviper
Apr 23, 2025 07:13 PM
Jul 16, 2017 07:33 AM
DerrickW
Nov 15, 2015 05:52 PM
rangomango
California
Sep 24, 2015 05:47 PM
