TL: Stereo Keeps Locking - Anti Theft Problem?
Old Feb 2, 2011 | 05:33 PM
RA121624-2's Avatar
Have a 2000 TL and about a week ago I started having some strange problems with the radio. I went to start it one morning and the stereo wasn't working and asked me for the code. I put it in, an other than losing all my presets, it worked fine.
Then about 2 days ago the stereo actually stayed on after I turned the ignition key and I removed the key. I started back up and shut down and it went off, but then it reset again and I had to put the code in.
Now it seems to be resetting just about every time I turn the ignition off. The next time I start up, I have to enter the code and pre-sets are gone.
I assume it's some sort of electrical/fuse problem with the stereo and it's losing power. This something I can check/fix on my own, or should I just head over to the dealer?
Old Feb 4, 2011 | 09:30 PM
Jonesi's Avatar
Seems odd.. weird... Does the connection to your battery have a lot of corrosion on it?
Old Feb 5, 2011 | 09:25 PM
RA121624-2's Avatar
Popped the hood today and checked. One of the terminals had a bit of corrosion, but not much. I pulled the cables, cleaned everything off and we'll see if that clears it up.
Thanks!
Old Feb 10, 2011 | 09:17 PM
KaMLuNg's Avatar
if that doesn't help, i would say next step would be to check the radio fuse...
Old Apr 26, 2011 | 09:08 AM
RA121624-2's Avatar
Alright, so, a new wrinkle to this issue. Last week or so, the stereo has started acting up. Often, none of the buttons will respond at all and sometimes even if I turn the ignition off and pull the key, the stereo actually stays on.
Any thoughts?
tman570
Jun 11, 2019 07:56 AM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
Kamakanani0
ILX Audio, Bluetooth, Electronics & Navigation
Nov 4, 2015 05:44 PM
Azonics
Sep 22, 2015 05:28 PM
Gianni Formica
Sep 7, 2015 08:28 PM
