Stereo connections HELP!!! (diagram)
Old Mar 11, 2005 | 01:49 PM
muffaburn's Avatar
Show me da MONEY
Asking all the audio guru's to chime in to let me know if this is correct. Would like to know the color of the wires to which I am tapping ( remote & 6x9 +/- ). Also want to know if the tapping for the LOC off of the 6x9's are being tapped from the correct location.
I have done searches on the boards and have gotten lots of info and just want to be positive of the setup. Thanks for all advice and any and all info...
Old Mar 11, 2005 | 02:11 PM
elduderino's Avatar
VP Electricity
You seem to be doing that right, I don't know the colors off the top of my head, but someone will... : )
Your diagram for the LOC doesn't show tapping both (+) and (-) on each speaker, but you do... just follow the LOC wiring instructions.
Old Mar 11, 2005 | 02:20 PM
NYZGREATST's Avatar
Sig Rho's Finest
looks like its all right. i dont have the colors though. i never tapped into the wire before the EQ. i know after the EQ its blue.
Old Mar 11, 2005 | 04:50 PM
muffaburn's Avatar
Show me da MONEY
amp wiring diagram
Not sure if this is the correct stock amp wiring diagram for the subwoofer, because of all the speaker inputs? If it is which wire can I tap for remote?
Old Mar 11, 2005 | 04:56 PM
dark inspire's Avatar
El Presidente
the 02 TL's have 6x9's? i thought all TL's had 6.5's
Old Mar 11, 2005 | 05:09 PM
muffaburn's Avatar
Show me da MONEY
oh, maybe they are 6x5's either way what are your thoughts?
Old Mar 11, 2005 | 05:12 PM
El Presidente
im not to knowledgealbe about amping the speakers, but what ive done is just to hook up the sub, is tapped the wires from the junction box from behind the rear seats and put those into the LOC and from that to the amp. It works well for the sub. Im not to sure about amping all the speakers. Ive got a diagram to do what i just described if you want that
Old Mar 11, 2005 | 05:16 PM
muffaburn's Avatar
Show me da MONEY
yes, i definetly want to see your diagram. you can email it to mburns05@hotmail.com
Old Mar 11, 2005 | 05:18 PM
muffaburn's Avatar
Show me da MONEY
Here are my instructions that came with the LOC
Old Mar 11, 2005 | 05:19 PM
El Presidente
yeah i got those same instructions ill email you my diagram for tappin the junction box
Old Mar 11, 2005 | 05:21 PM
El Presidente
sent
Old Mar 11, 2005 | 05:36 PM
muffaburn's Avatar
Show me da MONEY
Not to sure what junction box your speaking of. Is that right behind the passenger side back seat? It does seam a little easier to tap everything from one spot though.
Old Mar 11, 2005 | 05:39 PM
El Presidente
yeah its behind the passenger rear seat
Old Mar 11, 2005 | 05:42 PM
muffaburn's Avatar
Show me da MONEY
So that's not the amp then huh, just a junction. Is this on a TL or CL? I have a 02 TL
Old Mar 11, 2005 | 05:43 PM
El Presidente
I believe it is from a TL, not sure what year, but judging from the color, im thinkin its either 02 or 03
Old Mar 11, 2005 | 05:55 PM
muffaburn's Avatar
Show me da MONEY
Oh I thought that was your car. So all taps were done before the stock amp and after the stock EQ (assuming that silver box is the stock HU EQ) . Kinda looks like the taps were actually done between the EQ and the stock sub amp . Will this alter the the stock bose sub?
Old Mar 11, 2005 | 06:00 PM
El Presidente
the splices were done before the stock sub amp. If you are only adding an aftermarket sub, it works. The stock sub will still work if you splice it, but it sounds better w/out it.
Old Mar 11, 2005 | 09:22 PM
muffaburn's Avatar
Show me da MONEY
It seems like having the stock sub still connected would give more thump. So your saying without the stock sub it sounds better, how come?
Guys forgive me for all the questions I have not done a system in years.
By the way I just realized there aren't any 6x9's in the rear deck, just speakers in the rear doors (I feel like a idiot-DOHH!!!)
Old Mar 11, 2005 | 09:35 PM
El Presidente
yeah you would think it would sound better, but i noticed that when both subs are connected the stock sub and the aftermarket one fire at slightly different times, which to me was annoying. i dunno, maybe its just me, but it sounded way cleaner w/just the aftermarket sub.
Old Mar 12, 2005 | 09:31 AM
El Presidente
give it a shot, see what you think. I mean it's your car if you like the sound then leave it in, if not disconnect it. I personally didnt like the sound in conjunction with the aftermarket sound, so i disconnected it, removed it out of the rear deck and now have a port through which the aftermarket sub can enter cabin. it's your call
Old Mar 12, 2005 | 09:42 AM
muffaburn's Avatar
Show me da MONEY
Thanks dark dj, for all your info I really really appreciate it. By the way is that silver box near where you made the taps the stock EQ? I will try both ways to see if I like the sound with both subs or not. Any other tips and tricks you or anyone else can add would be appreciated.
Old Mar 12, 2005 | 10:21 AM
El Presidente
no probz man, which amp/sub are you going to be hooking up? the silverbox is the lil sub amp thingy, you'll see it better when you take it out its screwed onto the chassis.
Old Mar 12, 2005 | 10:48 AM
muffaburn's Avatar
Show me da MONEY
Bought these items from member NYZGREATST
https://acurazine.com/forums/car-parts-sale-361/f-s-amp-sub-digicap-custom-amp-cover-w-neon-fans-297382/
I thought the stock sub amp was behind the jack compartment in the trunk
Old Mar 12, 2005 | 10:51 AM
El Presidente
https://acurazine.com/forums/showthread.php?t=297382
oh ok cool! yeah, the lil amp is where the junctionbox is if im not mistaken
Old Mar 12, 2005 | 08:38 PM
muffaburn's Avatar
Show me da MONEY
So wait a little confused now. That silver box in your diagram is what, the stock sub amp or the stock EQ?
Old Mar 13, 2005 | 05:29 AM
ResidualFreedom's Avatar
2400 Watts in a TL...Why?
Keep in mind, I used a relay on the stock remote and when the car turned on there wasn't enough power in the remote wire to trip the relay... Had to step down to a computer style relay or run the remote directly off the fuse box, which is what I did.
Old Mar 13, 2005 | 11:31 AM
muffaburn's Avatar
Show me da MONEY
So if I see the amp not turning on/off it could mean the remote tapped from the orange line is not enough power to trip the amp's relay and I should then use a fuse from the fuse box? if that does happen (hopping it doesn't) which fuse would i need to tap from the fuse box?
Old Mar 13, 2005 | 12:16 PM
I'd have to check on the exact fuse.... but in the mean time if you were to connect a little wire from the 12v on the amp to the remote on the amp that will surely turn the amp on (it won't go off now, but this will check to make sure the amp is working).
like I metioned above, I had to do this, the stock remote wasn't strong enough to turn my amp on.
Old Mar 13, 2005 | 05:42 PM
muffaburn's Avatar
Show me da MONEY
In doing so will it drain the battery since the amp will always be on (or is this just temporary to make sure the amp works)? Hopefully I won't have to go this route and can just tap the remote off of the orange wire.
It would be great if you could let me know which fuse to tap just in case. I would have tapped off of either ciggy lighters but I already tapped off of them for my nav-dvd conversion. I tapped a couple of fuses already on the drivers side fuse box, one for my fog light mod and another for my indiglo gauges. I also tapped a fuse from the passenger side fuse box for my neon footwell sticks.
I ask this question again the silver box in the picture is what? (stock sub amp, stock EQ or just a junction box)
Old Mar 13, 2005 | 05:46 PM
elduderino's Avatar
VP Electricity
He was suggesting it as a temporary test.
Your fuse box idea is the wrong way. Buy a low voltage trigger unit like the PAC TR from Autotoys, if that's the problem.
Old Mar 13, 2005 | 06:00 PM
muffaburn's Avatar
Show me da MONEY
i will be doing the install sometime near the end of the week, hopefully whenever the sub, amp & cap get here. So i am just trying to gather all info.
Old Mar 13, 2005 | 06:10 PM
muffaburn's Avatar
Show me da MONEY
^^ne1^^
Old Mar 13, 2005 | 08:31 PM
muffaburn's Avatar
Show me da MONEY
Revised Diagram
Here is a revised diagram if going off of the above photo. Is this correct???
Old Mar 14, 2005 | 09:10 PM
perfect.. electrically that is..
4drviper
Apr 23, 2025 07:13 PM
quanaman
Jan 9, 2023 07:33 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
SilverJ
4G TL Problems & Fixes
15
Oct 13, 2015 05:14 PM
AmplifiedDetails
Sep 24, 2015 02:55 PM
