Steering wheel Audio controls
Old May 6, 2001 | 02:53 AM
dc121's Avatar
Post Steering wheel Audio controls
is there any way possible to change to an a/m head unit & keep the steering wheel control functioning?
'01 TL Taffeta White
18x8 Blitz Z2 Technospeed
Pirelli P7000SS 225/40/18
H&R SportSprings
Polarg M-12 Corners
Solaris High Beams
Old May 6, 2001 | 04:16 AM
bobatimez's Avatar
Post
is it possible to use the sterring wheel audio unit on another car (s2k)
Some Said, "TL Type S," Soon They Will Say, "Wannabe TL-S." Laguna METALLIC, Navi, Side Cuts, Tint All Around, Interior Footwell Lighting, Eibach ProKit, PIAA 1700x Fogs custom cut into side holes, Inspire Tails, 17" Type-S Rims with 215/45/17 Bridgestone Potenza RE730's, Visor, Wood Shifter, Comptech Sways making me ride on rails...
http://albums.photopoint.com/j/Album...026&Auth=false
Old May 6, 2001 | 10:39 AM
SteveStMS's Avatar
Post
Yes, you can keep using your steering wheel controls and even add 4 more steering wheel buttons (7 total) for a/m headunit. Your a/m headunit must have infrared control.
The part you need is Peripheral Components PESWI3. It's a infrared learning transmitter that has a single wire to hook-up to your factory radio plug.
See http://www.peripheral-aamp.com/perip..._interface.htm
If you want to add more buttons than the 3 factory, use the provided resistor network that came with the PESWI3 and add 4 Radio Shack buttons Cat.#: 275-646. These black (or red) buttons fit inside the 4 screw hole openings on the back side of the plastic covers on the steering wheel (At least they did on my Honda Odyssey, TL might be different). A little glue or black silicon holds them in place.
I can write up exactly how to do this and show a picture of my installed buttons if your interested.
Steve
<FONT COLOR="#800080" SIZE="1" FACE="Verdana, Arial">[This message has been edited by SteveStMS on May 06, 2001 @ ]</font>
Old May 6, 2001 | 11:07 PM
StreetEffectz's Avatar
Post
You are the man Steve! By the way, I have "4" of those parts coming in monday FINALLY so I will need 4 harnesses
Old May 6, 2001 | 11:27 PM
dc121's Avatar
Post
pictures would be great. does any particular brand head unit work better? thanks for info.
Old May 7, 2001 | 12:25 AM
SteveStMS's Avatar
Post
Any headunit with a infrared remote control should work. The installation issue is not will it work, but where to mount the infrared transmitter eye (LED sized). It needs to point at the head unit. A center console position pointing at the headunit can work good.
Old May 7, 2001 | 11:56 PM
StanMan's Avatar
Post
that is similar to the swc items from lightning audio and pac.
Old Jun 7, 2002 | 12:21 PM
pangpang77's Avatar
Steve,
Trying to revive this thread a bit. Can you post the instructions and pics especially for the 4 buttons?
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
PortlandRL
Sep 14, 2015 12:01 PM
Charlespsu
Sep 2, 2015 09:54 AM
MyKids&Cars
Sep 2, 2015 12:03 AM
