Steering wheel audio buttons not working properly
Old Feb 12, 2006 | 07:25 PM
FZ427's Avatar
Hello guys,
When I press the up or down volume on the steering wheel instead of changing the volume it changes to the next song, any ideas?
Thanks for any help.
Old Feb 12, 2006 | 07:43 PM
fodzy147's Avatar
check the buttons they may be stuck together. the middle button is what is supposed to change the song.
Old Feb 12, 2006 | 10:44 PM
TL83s's Avatar
03 ABP TL-S
If you still have your warranty take it to the dealer had mine fixed last month w/ my oil change and 2 brand new engine mounts for vibration at idle......hope this helps......
Old Feb 12, 2006 | 11:26 PM
FZ427's Avatar
TL83s: I know I might have to take it to the dealer even though I don't want to touch a single acura dealer around here. This car has poor quality and the dealer thinks that the customer it's at fault because I am not spending $300 plus for a 30k check up. When you go to the dealer for warranty work they treat you very bad at least to me.
Old Feb 13, 2006 | 05:53 PM
MurkyRiversTL's Avatar
COTM Coordinator
I have had the same problem with mine and then it started working fine. I think the buttons get stuck together...... not sure though. I am going to try and clean out the buttons and see if that works.
Old Nov 1, 2006 | 06:35 PM
03typeStl's Avatar
04 Black Infiniti I35
Why do they treat you bad ?
Old Nov 2, 2006 | 01:25 AM
FZ427's Avatar
they treat you like you dont know anything about cars and if you dont spend $$$ they take forever for ex. warranty work.
Old Nov 2, 2006 | 09:22 AM
LSBoogie's Avatar
There is an update for a grounding ring under the steering wheel. Have to remove the air bag and dimple the ground ring to improve the bad ground. There is also a grounding "tab" under there that should be cleaned and resecured if you are going to take it all apart. With the fact that the airbag is involved i don't know that i would tackle this as a DIY.
Old Nov 2, 2006 | 10:12 AM
fsttyms1's Avatar
I would look into a different dealer. Mine has never treated me like that
Old Nov 2, 2006 | 06:00 PM
03typeStl's Avatar
I gotta tell ya, my dealer where I bought my Acura from was very good to me, they gave me a free oil change coupon + an extra remote for the car and then when my car was having its purge valve (sp?) replaced they gave me an Acura TSX as a loaner ... not bad, didnt have to sit in and drive a piece of crap ford!
Old Nov 15, 2006 | 10:15 PM
bigbig_o's Avatar
7th Gear
had the same problem and fixed by the dealer. Get the impression that it is a common problem that they know about.
Old Nov 20, 2006 | 06:57 PM
jason0617's Avatar
Mine does this, too.
Old Nov 21, 2006 | 04:44 PM
Trackruner228's Avatar
Hm I have never had that problem with mine I would think it would be hard to get the middle button to stick to the other two buttons because it sticks out so far from the other two. At first it really bothered me though that it didnt light up at night but then I kinda got the point that the whole point of them is so you dont have to stop looking ahead so I got used to it. I think im way too used to it though because whenever I drive other cars I always go for the radio controls and its just like ummmm no.
Old Nov 21, 2006 | 07:41 PM
03typeStl's Avatar
Had this issue, took it to the dealer and they fixed it for no charge.
Old Nov 29, 2006 | 01:02 AM
CAB NY's Avatar
Tri State ViP Crew
having the same problem was yours still under warranty mine just ended if its alot to fix ill just use the radio
Old Nov 29, 2006 | 06:09 PM
03typeStl's Avatar
My car is a certified Acura so yes, it was under warranty.
Feb 25, 2020 09:57 AM
james357
Feb 13, 2016 02:37 PM
SpraykwoN
ILX
Sep 11, 2015 08:45 PM
Charlespsu
Sep 2, 2015 09:54 AM
MyKids&Cars
Sep 2, 2015 12:03 AM
