Speakers installation (help plz)
Old May 29, 2001 | 08:19 PM
AzNTL's Avatar
Question Speakers installation (help plz)
i just got the JL Audio VR600-CX (6") for the back and JL Audio XR650-CX (6.5") for the front. the backs did not fit perfectly into the white plastic basket after i did around 1" cut of the bottom of it, it still doest fit. is there a way to make them fit? how about the front (6.5") thnx a lot
Old May 29, 2001 | 09:15 PM
Lightbulb
I wouldn't use the plastic cups that the stock spkrs sit in - I made adapter rings for my 6.5" spkrs using MDF. You have to maintain the 1" thickness of the stock adapter cups so that you're new spkrs don't intrude into the door preventing your windows from going down.
If you are handy and have tools: trace the shape of the stock plastic spkr cup on a piece of MDF and mark the screw holes that go into the door. Also you need a 6.5" circle in the center of the adapter for your spkr. Use a jigsaw or sabre saw to cut the hole out and then cut the shape of the stock adapter. I used two 1/2" pieces of MDF and glued them together to make the 1" thick adapter. Drill holes where the door screws go and put it in. Then mount your spkrs to the new MDF rings. Here's how mine turned out.
FRONT
REAR
<A HREF="http://www.acura-tl.com/_borders/TL_in_Pacific_Grove.jpg" TARGET=_blank>1999 ACURA 3.2TL
</A>
Creating a true
Touring Legend...
Mods & stuff....
Old May 29, 2001 | 11:08 PM
j83's Avatar
j83
Post
tldaddy after adding that mdf board over it does it hit good bass? i know they only 6.5 but....im figuring some good results?
Old May 29, 2001 | 11:20 PM
Thumbs up
Oh yeah I've got some good amps driving them so you really feel the bass hit your legs. 6.5" 3-ways in fronts and 5.25" 2-ways in the rears - plus a 10" sub in the trunk - my system cranks
Old May 30, 2001 | 01:10 AM
valuetl's Avatar
Question
Daddy the mounting depth is the same in the front and rear doors I take it????
00 non navi TL Firepepper red/ebony, Value Sports Kit, Saber Foglamps, Factory rear spoiler, Gold and wood kits, wood wheel, 18" Altstadt's + Dunlop SP9000's, Apexi exhaust, A'pexi coilovers.Next up Headers
Old May 30, 2001 | 07:06 PM
Talking
Yes - about 1.75" of clearance behind the metal door panel so the speaker you install should be about 2.75" ~ 3" deep.
Feb 25, 2020 09:57 AM
TxRzrBk
Sep 17, 2015 01:07 PM
Pegon95
Sep 15, 2015 01:54 PM
alan_rich
Sep 7, 2015 11:08 PM
iRaw
ILX
Sep 5, 2015 12:10 AM
