Speaker intstall
Old Nov 8, 2003 | 07:07 PM
nguyenn's Avatar
Speaker intstall
Hello Guys,
I am planning to hook up the Boston Z6 to my CLS, and could you help or show me how to install it?
appreciate it
thanks
Old Nov 17, 2003 | 11:58 AM
fyud's Avatar
i installed my z6"s @ 1 year ago. The tweeters installed in the stock positions with just a little cutting. The 6.5" woofers/mid speakers required that I cut the existing speaker spacer to properly mount them in the doors. It was not very hard to do. If you have more questions pm me. I will respond.
Old Nov 17, 2003 | 02:13 PM
nguyenn's Avatar
Fyud,
Thank you very much for your help, and just one more question, where did you install the crossover? I am thinking of cutting and modifying my doors, but I don't know how to do it yet. The other option is installed them in the trunk. What do you think?
thanks again
Old Nov 17, 2003 | 02:18 PM
Six Shifter's Avatar
an adult perspective
why "cut and modify"? while you have the stock speakers out, you should be able to feel around and notice where there is some space in the lower front portions of the door where nothing gets in the way. then, you have some options: 1) double sided tape 2) use the x-over as a template, mark the holes where the screws would go, and drill (with the thought of bolting the x-overs as opposed to screwing them in) 3) same template and get a long tie-wrap and snug that sucker up!
Old Nov 19, 2003 | 02:30 PM
fyud's Avatar
I put the crossovers in the bottom of the door. If you remove the door panels and look inside the door you will see plenty of space.
i used velcro to secure the xovers.
Old Nov 19, 2003 | 07:11 PM
nguyenn's Avatar
Fyud
Thank you very much for the tip, I am going to install my system this weekend and hopefully everthing is going smoothy.
Thanks again
4drviper
Apr 23, 2025 07:13 PM
kb1rl
Sep 30, 2015 10:17 AM
polish_pat
Sep 25, 2015 12:24 PM
rboller
Sep 23, 2015 02:49 PM
