Speaker Grill
Old Apr 7, 2001 | 12:30 PM
001 TL's Avatar
Post Speaker Grill
I Want to replace my speaker in the door pannel but before I do, I would like to know if I have to remove the pannel or just the grill and if just the grill how do I remove without damaging the grill and pannel???
Old Apr 7, 2001 | 06:12 PM
Post
You have to remove the entire door panel. It just snaps off. Leave the door handle attached, but remove the plastic covering that is held in place with the screw. Also, check the mounting depth of the speakers you are going to replace and make sure there is enough room for the magnet in the door. If there isn't enough room, you will need to buy or build spacers for the speaker, which may (most likely will) require modification to the speaker grills in order for the new speakers to fit.
2001 Nighthawk Black Pearl / Parchment Interior
Acura DVD-Based Navigational system
Burlwood Shifter
Alpine 620 Changer
2002 Wood vent trim
Flush mounted burlwood Startac handsfree kit
Passport 8500
Heavy Right Foot
Old Apr 8, 2001 | 06:12 PM
Lightbulb
You have to remove the door panel - the grill is built into it.
The chrome door handle comes off with the plastic cup it sits in. There is also a large screw under the arm rest you need to remove. You can put up to a 6.5" spkr in the doors but will need to make adapters for you spkrs to mount - then bolt the adapters to the doors. Made mine from MDF.
<A HREF="http://www.acura-tl.com/_borders/TL_in_Pacific_Grove.jpg" TARGET=_blank>1999 ACURA 3.2TL
</A>
Mods & stuff....
Old Apr 8, 2001 | 06:28 PM
Post
Oh that's right, the handle does come off, but the assembly stays... Thanks TL Daddy!
Burlwood Shifter
Alpine 620 Changer
2002 Wood vent trim
Passport 8500
Heavy Right Foot
Old Apr 8, 2001 | 07:44 PM
001 TL's Avatar
Smile
Thanks for the much need help, will be starting the upgrade next weekend..
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
kb1rl
Sep 30, 2015 10:17 AM
rhdune16
Sep 28, 2015 11:31 AM
polish_pat
Sep 25, 2015 12:24 PM
