Speaker depth 2G
Old Apr 3, 2006 | 07:44 PM
vtlec01's Avatar
Speaker depth 2G
Did my research but didnt exactly find the answer. What is the deepest speaker someone has put into the doors? ive read they suggest 2 - 2 1/16 but i was wondering how big you can get it with spacers and no problems. Thanks ahead.
Old Apr 3, 2006 | 08:01 PM
Jonesi's Avatar
What year and model acura?
Old Apr 4, 2006 | 07:56 AM
vtlec01's Avatar
01 tlp really hoping to get a 2 3/4 type r component.
Old Apr 4, 2006 | 05:43 PM
vtlec01's Avatar
anyone? im gonna post this in the 2G FORUM as well
Old Apr 4, 2006 | 06:02 PM
ou sig's Avatar
Boomer SOONER
not very much at all - I have the Focal "slim" series and they clear with like 1/8 of an inch left. I think they are 2 1/8 inch deep - not much. You can make a spacer out of plywood/mdf - but not much more than 1/2 inch or the door panel wont snap back on . You need to get a speaker that isnt very deep.
Old Apr 4, 2006 | 07:37 PM
JMAL's Avatar
i got the focal access components, are you happy with focal? i havnet had a chance to install them yet, and idea about how much spacer i need?
Old Jun 14, 2006 | 04:56 PM
JMAL's Avatar
sorry for the dig here, but i at one point wanted to know this too. i installed focal access 165a into my car, all i did was put some rubberized foam insulation between the basket and the speaker, and cut the back of the basket off/notch the ring to sit speaker and trim the tabs off. no prob, clears the window np. front doors i trimmed the bottom od the door cut out to clear the speaker terminals with no problems. all you need is a dremel. the 165a is 2.6" deep
Old Jun 22, 2006 | 04:22 AM
helomech's Avatar
5th Gear
A newbee here, I just bought my 06 tsx last week and I had a set of Polk Audio I had just bought for my old car, I actually got them to fit in the TSX. They are the MMC6500's and the mounting depth is 2-13/16" (7.14cm). I had to cut the door hole a little bigger and then i just put some foam around the space between the door and the speaker so the speaker would match up to the factory grill. I also had 5x7 MMC5700 series with a mounting depth of 2-11/16" (6.83cm) that I had installed in the rear doors. I just took a jig saw to make the oval hole and did the same with the foam. They sound awesome, crystal clear sound (but not as loud w/o an amp). I didn't take pics, but I will be pulling the panels back off to sound proof very soon. if anyone is interested, I could post some pics when I do this.
Old Jun 22, 2006 | 07:43 AM
RuthlessPastor's Avatar
2001 CL Type S
I'd like to see some pics of the front doors. I don't know how they compare to a CLS, but any input would be good. What are you going to use to sound deaden?
Old Jun 22, 2006 | 05:53 PM
helomech's Avatar
5th Gear
I'll get pics up this weekend. as far as sound, there is this stuff at Home Depot called "Storm Guard". It comes in a roll like roofing tar (the material has clear plastic on one side and a peel off paper back on the other) This works the exact same as Dynomate but extremly cheaper. A friend told me about this so I did my trunk already and it's all true. No rattles. The peel off side is sticky, so no need for glue. This does sound like a cheap way to go, but every litlle bit helps.
4drviper
Apr 23, 2025 07:13 PM
kb1rl
Sep 30, 2015 10:17 AM
polish_pat
Sep 25, 2015 12:24 PM
rboller
Sep 23, 2015 02:49 PM
