spacer for speaker
Old 12-26-2004 | 12:20 AM
uncleb's Avatar
spacer for speaker
i ran into another problem when putting in my speakers. i have a pair of focal utopia components, which are quite deep, so i'm going to have to make a spacer ring for it so that the window can roll down without any problems. the thing about this is that if i put the spacer in, then the speaker will stick out too far and i don't think i will be able to put the door panel back on. any suggestions on how to get around this problem??
for those with a 2nd gen tl, how did you guys put in your aftermarket components??
Old 12-26-2004 | 08:26 AM
shawhite's Avatar
you have plenty of room under the door panel... i have a 1 inch spacer with my boston pro components and they still fit pretty easily... so i dont think you are going to have a problem..
Old 12-26-2004 | 10:15 AM
phipark's Avatar
Not Asian
You won't have a problem with the door panel. Plenty of people have installed the same type of speakers w/spacers and didn't have a problem.
Old 12-26-2004 | 11:33 AM
ou sig's Avatar
Boomer SOONER
not those speakers in our cars...why would you think that? The Utopia's are freaking bad ass!!! and deep. Congrats on that purchase BTW. What amp do you have on them?
Old 12-26-2004 | 09:05 PM
uncleb's Avatar
ok, looking at the stock speaker, i know it presses against the door panel, which is why i'm trippin that the aftermarket ones might rub it....but fuck it, i take your word. a-tl has helped me get a lot of shit done!! did you guys leave the speaker bare and put the panel on, or did you put the cover (that came with it) and then the panel??
Old 12-26-2004 | 09:07 PM
uncleb's Avatar
thanks bro, i want to get them damn things in already though....they've been in my closet for a few months already....just barely got my amp for it. i'll be running them off a usamp 400x.
Old 12-29-2004 | 07:12 PM
VTEC11's Avatar
Just install your speaker with your ring. There is no other cover besides the door panel. Are you talking about the white bracket the stock speaker sits in? Just take that out all together when you put on your new spacer ring.
Old 12-29-2004 | 09:03 PM
uncleb's Avatar
i am talking about the door panel, there's this circular part which is padded with foam, and it pushes up against the stock speaker because i can see the indent in the foam part. i was just kinda worried that the new speakers might push against it too hard, ruining anything......
also, do you guys cover the back of the speaker, to ensure that the window has no effect on it, or do you just leave it bare??
Old 12-29-2004 | 10:14 PM
DerrickM's Avatar
Cut the door panel where the sticky foam is to prevent it hitting your rubber surrounds. (I also cut out as much as I could that was in front of the speaker, and covered what remained with silicone rubber).
I left my speaker bare, but I can't say that's the best thing...
kb1rl
09-30-2015 10:17 AM
polish_pat
09-25-2015 12:24 PM
Quick Reply: spacer for speaker
