CD CHanger question
Old Dec 22, 2004 | 03:53 PM
acuraplaya's Avatar
CD CHanger question
I have a 1998 3.0CL with bose OEM. I read somewhere that these models came with a 8-pin changer connection in the trunk to connect an external CD changer. I cannot locate this connection int he trunk and not too sure how to remove the HU to get the connection. please help...i ahev all the cables and adapter needed to hook it up.
thanks
(98 3.0CL, BLK with BoseOEM)
Old Dec 24, 2004 | 02:05 PM
circuitcah's Avatar
Connection is on the back of the in-dash (it is more than 8-pin). Acura did not pre-run the cable in these cars. You need to remove the center console to get the deck out. Then plug in your adapter, run the cable, and mount the changer.
Good luck!
Old Dec 25, 2004 | 03:04 PM
acuraplaya's Avatar
ok, so how do i remove the center console?
Good luck!
Old Dec 30, 2004 | 12:46 AM
circuitcah's Avatar
It's kind a hard to explain in text......
Basically, you remove the back part of the console (that has the armrest/storage compartment) to get to the screws that hold the front part. Then remove all of the screws in the front part of the console (has the transmission shifter in it and goes up around the radio). I remember that there is a hidden screw up behind the ashtray. Once all of the screws are out it should unsnap. The radio will have two screws in the backet below the pocket and the pocket and radio will come out as one unit. Reinstall by reversing the steps.
Sorry, I couldn't describe it in more detail. Hope this helps.
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
navtool.com
Sep 25, 2015 05:15 PM
