Soundgate loc's
Old May 4, 2004 | 04:18 PM
Soundgate loc's
Anybody using soundgate's line output converter's to run aftermarket amp's from the factory headunit? I am still getting hiss at low volume level. On the converter's the gain is adjusted by dip switch's. I was wondering if anybody have had expierence with these?
Old May 5, 2004 | 09:55 AM
VTEC11's Avatar
davey73,
what's the model# on your LOC. I believe it is similar to the david navone LOC that i have. I get a slight hiss at low volume too if it turn gains up. But Idon't think its because of the LOC, since I also used DEI LOC's and it did the same thing. It sounds like hiss but in my case its actually picking up a very low level noise that's somehow getting into the RCA's. I'm thinking, it could be because of the way the RCA's are routed and/or because i left the LOC behind the radio where there are tons of other wires on top of it.
Can anyone help?
Old May 5, 2004 | 03:34 PM
shogun's Avatar
im the best
is a loc always needed when keeping the hu and speakers and just swapping the sub and amp?
Old May 5, 2004 | 04:25 PM
yes
Old May 5, 2004 | 04:28 PM
Originally Posted by vtec11
davey73,
Can anyone help?
I am using 2 of these...http://www.logjamelectronics.com/sounlocbosli.html Also the dip switch's are inside the loc. There is 8 of them.
Old May 5, 2004 | 05:33 PM
shogun's Avatar
im the best
why 2? sorry i dont know anything haha
Old May 5, 2004 | 05:41 PM
They only come in 2 channel. And i'm running a 4 channel amp.
Old May 8, 2004 | 10:23 AM
shogun's Avatar
im the best
im getting a mono amp and a single sub and plan to just swap the stock sub and amp. is this what i should do?:
1) use existing remote
2) run new power/ground
3) use loc at headunit? or at stock amp location?
4) which loc could/should i use?
thanks, for the most part i think the loc is the part im unsure about now (what kind,etc)
alan_rich
Sep 7, 2015 11:08 PM
Girth
38
Jan 29, 2005 12:07 AM
Acuraluvr
Jan 15, 2005 01:01 PM
