Soundgate loc's
Soundgate loc's
Anybody using soundgate's line output converter's to run aftermarket amp's from the factory headunit? I am still getting hiss at low volume level. On the converter's the gain is adjusted by dip switch's. I was wondering if anybody have had expierence with these?
davey73,
what's the model# on your LOC. I believe it is similar to the david navone LOC that i have. I get a slight hiss at low volume too if it turn gains up. But Idon't think its because of the LOC, since I also used DEI LOC's and it did the same thing. It sounds like hiss but in my case its actually picking up a very low level noise that's somehow getting into the RCA's. I'm thinking, it could be because of the way the RCA's are routed and/or because i left the LOC behind the radio where there are tons of other wires on top of it.
Can anyone help?
Can anyone help?
Originally Posted by vtec11
davey73,
Can anyone help?
Can anyone help?
im getting a mono amp and a single sub and plan to just swap the stock sub and amp. is this what i should do?:
1) use existing remote
2) run new power/ground
3) use loc at headunit? or at stock amp location?
4) which loc could/should i use?
thanks, for the most part i think the loc is the part im unsure about now (what kind,etc)
alan_rich
09-07-2015 11:08 PM
Girth
38
01-29-2005 12:07 AM
