Snhond3 Installation
Old Apr 6, 2005 | 08:28 PM
cArKc's Avatar
crc
i need to know how to connect the rca filter to the turbo 1. conencted the GLI rca filter to the snhond3 but need to know how to conect the turbo1 to the GLI rca filter. they both need plugs to go into them. thx
Old Apr 6, 2005 | 08:56 PM
Dan Martin's Avatar
Photography Nerd
turbo?
Old Apr 6, 2005 | 11:28 PM
cArKc's Avatar
crc
it is used to boost the db i think. or make it louder
Old Apr 6, 2005 | 11:40 PM
elduderino's Avatar
VP Electricity
I'm going out on a limb here, but I think you have the PAC turbo line driver and you ahve the SHOND and they both have female RCA ends? Which would mean you need a male to male RCA? Just shooting in the dark here...
Old Apr 7, 2005 | 01:00 AM
Tsx536's Avatar
Rep'n Taxbrain.com
Eld is dead on. He's got a PAC Turbo 1 Line driver along with the SNHOND3, and he's trying to hook his mp3 player up.
Sounds like he just needs another RCA cable.
Old Apr 7, 2005 | 09:43 AM
cArKc's Avatar
crc
yea... im gonna go to radio shack today to see if they got the RCA cable with 2 male ends
Old Apr 7, 2005 | 10:52 PM
cArKc's Avatar
crc
evrything works well without the pac 1 turbo, but after i plug the apc 1 turbo in it doesnt work. the guy at radio shack said that you need to power the pac 1 turbo inorder for it to work. is this true and how do i get power to it?
Old Apr 8, 2005 | 04:53 PM
Tsx536's Avatar
Rep'n Taxbrain.com
Yes this it true. It needs power. So are you happy with the sound without the Line driver? Do you get any ground noise? Do you have to turn the volume up on the Stock HU extremely high in order to be able to hear it well?
If you're happy with it, you can just return the line driver or sell it in the black market section here.
If you want to hook it up, you just need power and ground. In the TSX you can get it a lot of different ways. Here are some options:
1) Ignition - Get the power from the ACC (Accesory output) of the ignition
2) Get power/ground by tapping into the 12v power plug next to the NOT AN ASHTRAY
3) Get power from the fuse box using an add a circuit. Ground to a bolt in the fusebox.
The 2nd and 3rd option are the easiest ones to do. I think the 3rd one is the easiet actually. Let me know if you need more info.
Old Apr 8, 2005 | 05:30 PM
cArKc's Avatar
crc
how do i Get power from the fuse box using an add a circuit. Ground to a bolt in the fusebox.
Old Apr 8, 2005 | 05:33 PM
cArKc's Avatar
crc
tryied sending you a pm too, your box is full
Old Apr 8, 2005 | 06:01 PM
Tsx536's Avatar
Rep'n Taxbrain.com
Go to this thread and read about how another user did his:
https://acurazine.com/forums/showthr...light=tsx+fuse
*Note: Do not hook the red power wire of the Line driver to the Constant power shown in the picture. Hook it to the ACC power. The different between the two is that ACC only receives power while the car is on, while Constant is always receiving consistent power regardless of if the ignition is on.
Here's the diagram.
For power supply, I didn’t want to damage or splice into any factory wiring… So I check out the fuse box and found some empty slots. The top row has empty slots that provide switched (ACC) power and the middle row has empty slots that provide constant power. The bolt under the fuse box is convenient to use as a ground. I used the Mini Add-A-Circuit that I bought at Auto Zone to place into the fuse box (I had purchased two of these before looking at the fuse box).
Old Apr 8, 2005 | 06:23 PM
cArKc's Avatar
crc
hmmm.. where is this fuse box loacated??
Old Apr 8, 2005 | 06:27 PM
Tsx536's Avatar
Rep'n Taxbrain.com
On the driver's side. Close to where your left foot would sit while driving. It has a cover that you have to slide off by pulling it towards you. Just get really low and look in there and you should be able to see where it is and how the cover comes off.
Old Apr 8, 2005 | 06:33 PM
cArKc's Avatar
crc
hmmm....how would i get the pack1 turbo wire there? its the single brown one and its only about 5 inchs long
Old Apr 8, 2005 | 07:27 PM
Tsx536's Avatar
Rep'n Taxbrain.com
You would need to buy some more wire and connect both of them together. Ask the guys at radio shack about what you need. Just bring in the Line driver and tell them you need to add 3-4 feet of wire.
If you don't want to do this, you could probably just connect to the 12V power of the outlet next to the NOT AN ASHTRAY, the only bad thing about this is you would have to take off the cover around the transmission area, which you might not know how to do. Taking the transmission area apart the first time is a little scary, so I don't think I would recommend it if you are a noob.
cycdaniel
Dec 17, 2019 10:58 AM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
pistacio
Sep 26, 2015 09:45 AM
TxRzrBk
Sep 17, 2015 01:07 PM
