Sirius
Old Dec 13, 2005 | 03:54 PM
Esarey's Avatar
Sirius
Had a Sirius Starmate Replay installed in my Acura 2004 TSX. I have to turn the Sirius down, or I receive static in my speakers when my radio volume is turned up. The quality of my regular stereo, through the speakers, is much better. I have a FM modulator, and an installer told me that was the problem. He said the quality is better when it is directly hooked into the stereo through the AUX button. He then said that this was not capable right now with Sirius, only XM.
What should I do? Will I continue to have to turn my radio up to the highest setting, and turn my Sirius radio down, to achieve no static?
Also, even when I turn the Sirius down; the quality is still an issue.
Old Dec 13, 2005 | 03:56 PM
glott's Avatar
its possible, all you need is the blitzsafe adapter for your car, then you can use the AUX. Try www.logjamz.com or just search around here for blitzsafe. It basically gives you an RCA input with which you just use an RCA (red/white) to 1/8" (headphone) cable which plugs directly into your sirius starmate. Hope that helps
Old Dec 13, 2005 | 04:07 PM
Esarey's Avatar
Thank You.
Old Dec 13, 2005 | 05:00 PM
CJams's Avatar
Guinea Pig
Yep! FM modulation sux! what glott said!
Old Dec 16, 2005 | 02:04 PM
ScoHo's Avatar
I just got the Starmate Replay installed using the Aux (with the Blitzsafe adapter), and I'm having the same issue. It might not be as bad as what you're describing, but I do have to turn the volume on the Replay unit to about 75% - any higher, and I get that static. So then from there I use the stock volume, but it is much lower than the AM/FM/CD volume, so if I switch modes and forget to turn the volume down I get blasted.
The best way I can describe the audio of the Sirius is that it sounds like a very clear AM station. Doesn't sound nearly as good as my FM or CD.
Old Dec 16, 2005 | 03:47 PM
Tsx536's Avatar
Rep'n Taxbrain.com
So you hit the AUX button whenever you want to listen to it?
You're not listening to it through an FM station right?
If the volume is too low, you can put in a line driver to help boost the signal going from the starmate replay into your blitzsafe.
Old Dec 16, 2005 | 09:34 PM
ScoHo's Avatar
Correct, I'm hitting the CD/Aux button to listen, and it goes to CD-C mode (usually - but that's another story).
It's funny you ask that though, because the way it sounds, I feel as if I'm using the FM Modulator, but I'm definitely not. It's very disappointing.
Old Dec 16, 2005 | 11:19 PM
Tsx536's Avatar
Rep'n Taxbrain.com
How does Channel 1 sound?
It's the Sirius Hits Channel. That's usually the channel with the best sound.
Old Dec 17, 2005 | 07:53 AM
ScoHo's Avatar
Don't think I've gone to Channel 1, but I can tell you that the Howard channel seems to sound better than the rest.
Old Dec 17, 2005 | 11:24 AM
RMATIC09's Avatar
Hey, i have the same exact thing. Right now my sirius has quite a bit of static, cause it is not directly hooked up to the radio. MY installer told me he got a new piece in (im not sure what it is) that can be installed so it is connected directly into my radio, without the use of a switch to activate it.
THe way im setup is i just set the FM signal to a channel, and preset it as if its a radio station. For example, right now i use 90.1 and whenever i tune into that radio station and my sirius is on, i have sirius playing....
Old Dec 17, 2005 | 03:57 PM
I'm Batman's Avatar
Boom goes the Dynamite
By this time next year Sirius will be bankrupt...
Old Dec 17, 2005 | 09:13 PM
ScoHo's Avatar
Thanks for the info.
Old Dec 17, 2005 | 10:33 PM
curls's Avatar
Someone stole "My Garage"
I have the same problem -- Sirius Starmate, just installed today. Full reception from the satellite, but the sound quality sounds REALLY REALLY poor (like a 64 kbps mp3) and also, the FM modulator sounds tinny and staticy.
I don't want to hard wire anything using a Blitzsafe adaptor, because I'm not even sure I like Sirius (or satellite radio, period), as the compression of the audio is extremely noticeable and irritating.
Anyone know if a separate FM transmitter (not the built-in one) will help boost the signal so at least the static is gone (I'll deal with the compressed audio by cancelling my service if it comes to that, but I want to at least try it first).
Anyone?
Thanks,
Eric
Old Dec 18, 2005 | 12:15 PM
RMATIC09's Avatar
Doubt it.
Old Dec 21, 2005 | 02:52 PM
HeadHunter's Avatar
Eric
To be honest, don't expect CD sound from Sat Radio. Its bandwidth is small and all those stations are divided up based on popularity and required bandwidth. If you want sound quality, you won't find it here. But if you are okay with not the greatest sound, 120 channells will not find you bored driving around town.
koju01
ILX Audio, Bluetooth, Electronics & Navigation
Dec 14, 2015 02:17 PM
blacktsxwagon
Oct 27, 2015 10:12 PM
mgbe11
1/2G MDX (2001-2013)
Sep 15, 2015 07:53 PM
iRaw
ILX
Sep 5, 2015 12:10 AM
