single 10" sub positioning and firing?
Old May 4, 2004 | 04:31 PM
oo7bondgrrl's Avatar
i'd only driven hatchbacks before the tsx, so i don't really know how trunk boxes work. i'm going to have a single 10" type-s, and i'm removing the 6x9s. where's the best place for the box, and in what direction should it be aimed?
Old May 4, 2004 | 04:58 PM
Sturm's Avatar
TSX Bronco
Is this a ported box? I'm not an expert or anything, but I have 10" sub in a ported box and I just have it pointing towards the rear. I can't tell you if that's the optimal setup, but it sounds good to me. I'd be interested in hearing people's thoughts on this too.
Old May 4, 2004 | 10:41 PM
musicbox's Avatar
2004 TSX
Yes, pointed to the rear is usually the best. If it's a box you can move around, move it around every few days and see where you like it.
Old May 5, 2004 | 08:22 PM
tuan209's Avatar
ya...just try different places. can you go free air? i think i may give it a try.
Old May 5, 2004 | 10:30 PM
e_lectro's Avatar
Still here
oo7bondgrrl-
For positions, I would recomend trying:
~ under rear deck, centered, facing towards the rear bumper.
~ one of the rear corners, facing towards the other rear corner.
Those will typically give you your best result in a trunk. But if you have the time, and the extra wire, try both of those positions firing in all different directions. Just make sure to be consistant when you are testing, play the same tracks at the same volumes, under the same conditions. Good Luck and Have Fun
tuan209-
Free air is a bad option in our cars. It would take quite abit of work to truely seal off the trunk from the rest of the car. If you don't seal it off, you will end up with dismal results. I'm not saying it can't be done, IASCA world champion Scott Buwalda is doing it in his Altima, but a box would just be simpler.
e_lectro
EDIT: I'm not sure where you are located, but if you're in the surrounding area, I'd be happy to help you install a setup.
Old May 5, 2004 | 10:39 PM
Bass Mechanic's Avatar
listen to electro i tought him everything he knows! lol just kidding , but i would have given the same advise
Old May 5, 2004 | 10:44 PM
tuan209's Avatar
i talked to scott about it already.
only reason im considering doing it is b/c i want to save some trunk space, and like the sleathy look it would give.
Electro....just curious and i dont understand why you think its a bad idea, please explain. why would sealing of the trunk from the rest of the car matter?
Old May 5, 2004 | 10:48 PM
Dan Martin's Avatar
Photography Nerd
Originally posted by e_lectro
oo7bondgrrl-
That sounds kinky!
Old May 6, 2004 | 08:15 AM
davestar's Avatar
tuan: free air (or infinite baffle) drivers operate on the principal that the air space in front of the driver is completely seperate from the airspace behind the driver. otherwise, interference will occur. i was thinking about mounting 8s on the rear deck, but it sounds like it'll be too much hassle to seal the trunk/deck and at best i won't get good transient response.
Old May 6, 2004 | 08:32 AM
tuan209's Avatar
ya...did some research. im try it to see how it sounds. =D maybe the rear seats are good enough? if not i may build a wall or something. never went free air before, so ill give it a go. should be more balance but lose alil output.
Old May 6, 2004 | 03:23 PM
davestar's Avatar
cool, good luck with that. let us know how it sounds (and what you used if it sounds good!).
Old May 6, 2004 | 04:05 PM
tuan209's Avatar
sure will dave. i talked to scott and a couple of ppl about it, and they said with the back seats folded up it should be good enough. basically they told me i may lose a 10th of a db. no biggie to me.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
mlody
Dec 4, 2019 02:11 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
