?? Which side to run the RCA's to the trunk??
Old May 15, 2002 | 12:25 PM
2007AcuraRL's Avatar
Question ?? Which side to run the RCA's to the trunk??
Just about to pull the car apart to install the system. Typically, i run the RCA cables down the middle of the car flat under the carpet and rear seat into the trunk to avoid having the wires run to close to all the electrical wiring thats usually running front to back on the left and right sides of the car. Just wondered if anyone has had any particularly good (or bad) experiences with engine noise problems depending where they ran their RCA wires down from. I usually run power from the battery down the left side btw.
Old May 15, 2002 | 01:55 PM
If you run the power wire from the battery down the left side, then run the RCAs down the middle or right side.
Old May 15, 2002 | 06:45 PM
shawhite's Avatar
why run the rca down one side and the power wire down another sounds like a lot of unnessicary work to me....personally i ran all mine down the drivers side of the car but you could run it down either side with no problems.....
Old May 15, 2002 | 07:13 PM
NsX Pilot's Avatar
your 100% correct in what your doing with the wiring in seperating the power from the signal wires......and dont use cheap wires and audio cable and make sure u have a good ground for everything
mada51589
Jan 9, 2025 04:40 PM
benny_jdm
Jan 31, 2016 06:15 AM
nanos
Nov 12, 2015 08:41 PM
PortlandRL
Sep 14, 2015 12:01 PM
alan_rich
Sep 7, 2015 11:08 PM
