Running wires to large center console bin
CeD
Hey all,
I need to run some wires to the center console bin located above the "not an ash tray" bin. I noticed that there is a cap on the roof of that bin that pops out to be able to pass wires through. However, I can't figure out how to get that cap out. Any ideas?
Also, is that hole somehow accessible without removing the head unit? Could wires be pulled up there from the area beside the pedals if I were to push something down there to fish the wires up?
My Garage
just pull the bin out, it pops out easily, open the not-an-ashtray bin to give yourself room to grab (with your thumb and pointer finger) it at the bottom and use your other fingers to push against the side walls and pull at the same time. Hope you get what i'm saying.
just don't pull on the the tray door
I miss my 03 CL-S :(
Like Gibson said, apply pressure to the side walls from the inside. When you pop it out, the little light goes down and into the console, not out. So don't try to pull on the light itself, push.
CeD
Hey guys,
I applied pressure to the left and right sidewall from the inside while pulling it back and it's not coming out. Any thoughts?
Also, That little light came loose when I pried a small screwdriver underneath the cap and now it's no longer sitting in the hole. It's loose and causing a loud vibration noise. How can I get that thing back in there? I tried pulling it through with my fingers and it wont work since the bin is so tight.
CeD
So pull on the bin at the bottom with the "not an ash tray" door open while applying pressure to the sidewalls? Is there a specific area of the sidewall or does it not matter?
by applying pressure, Gibson means for you to basically put your 4 fingers of both hands on the inside walls of the compartment, with your thumbs on the outside, grip it and just pull it out. Should be that easy! No screwdrivers needed.
Good luck!
Good luck!
Oakes
Wash & Wax
10-12-2015 11:17 AM
