Running Wires???
Old Jun 29, 2004 | 04:41 PM
theac00's Avatar
Running Wires???
Hey I have a 00 TL and im takin the system out of my old car and puttin it in the TL. I was just wondering where anybody ran the power wire from the battery, rcas,remote wire, etc.. Since the back seat wont fold down, I guess running them through the cab isn't an option. Where is the best place to run them into the trunk....under the car and up through the trunk????
Old Jun 29, 2004 | 05:04 PM
shawhite's Avatar
wow... so since the back seat does not fold down that means you have to run the cables on the outside of the car.. lol.. you might want to do a search on this subject before you start running the cables.. but i ran mine thru the little grommet on the firewall right above the gas pedal.. then down along side the inside of the car and into the trunk...
Old Jun 29, 2004 | 06:44 PM
bayarea's Avatar
I am having the same problem, and I think I'm gonna run the wires thru the cab and then in between the back of the seat and the bottom to the middle and drill and hole thru the plastic dealy.
Old Jun 29, 2004 | 08:48 PM
Bxscig's Avatar
I was able to run it thru the side of the door sills and then under the seat to the back
Old Jun 30, 2004 | 08:31 AM
shawhite's Avatar
you wont even need to drill a whole in the plastic trunk piece.. there are slits at the bottom corner that you can run the wire thru..
Old Jun 30, 2004 | 03:13 PM
NYZGREATST's Avatar
Sig Rho's Finest
geez guys ur resorting to some extreme measures there, do what shawhite says, there are slits in the carpeting in the trunk. stick a wire hanger threw it and tape your wires to it at the other end and pull it thru.
Old Jul 6, 2004 | 02:01 PM
pravin.george's Avatar
Athena says 'hi'
Guys -- Just take out the back seat -- it's REALLY REALLY easy to do..
if you need instructions -- PM me or e-mail me.
I'll send you pics. I just did it two days ago.
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
VA2000TL
Oct 2, 2015 08:26 AM
JarrettLauderdale
2G CL Dynograph Gallery
Sep 21, 2015 07:51 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
