Running power cable.... Help please
Old Dec 7, 2001 | 08:46 AM
JasonT's Avatar
I see the hole through the firewall. I can get the seat out, now how do I take the door sill moldings, & the trim around the door piller off to feed the cable through?
Old Dec 7, 2001 | 09:05 AM
icy CL's Avatar
Re: Running power cable.... Help please
just pull the door sill molding up. there should be like 4 or 5 clips holding it down. the front panel by the foot brake should come off by pulling it out towards the right. you have to remove the seat to run the power cable? you don't need to remove the seat. if you're talking about the rear seats...yes, it would be easier to run the cable if you remove the bottom cushion.
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
VA2000TL
Oct 2, 2015 08:26 AM
Rob144
Sep 21, 2015 08:18 AM
