Reprograming remotes
HI! I have three remotes, when I got my 3rd one programmed, the one I did not have there at the time stopped working. I saw it was a very easy thing to do, it took the guy 3 min to do in the parking lot. I am just wondering if I can save a trip back to the dealer and a bit of coin. There is a serious of steps and I am hopping that someone could help me out and tell me the steps exactly. Thanks!
Still here
Transmitter Programming
The codes of up to 3 transmitters can be stored into the keyless receiver unnit memory. (If a forth code is stored, the code which was input first will be erased.)
NOTE: It is important to maintain the time limits between the steps. Make sure the doors, the hood, and the tailgate are closed.
[list=1][*]Turn the ignition siwtch ON (II).
[*]Within 1 to 4 sec, press the transmitter lock or unlock button with the transmitter aimed at the keyless receiver in the power window master switch.
[*]Within 1 to 4 sec, turn the ignition switch OFF.
[*]Within 1 to 4 sec, turn the ignition switch ON (II).
[*]Within 1 to 4 sec, press the transmitter lock or unlock button with the transmitter aimed at the keyless receiver in the power wondow master switch.
[*]Within 1 to 4 sec, press the transmitter lock or unlock button with the transmitter aimed a the keyless receiver in the power window master switch.
[*]Withing 1 to 4 sec, turn the ignition switch OFF.
[*]Within 4 sec, turn the ignition switch ON (II).
[*]Confirm you can hear the sound of the door lock actuators within 1 to 4 sec, then push the transmitter lock or unlock button again, or the code will not be stored.
[*]Within 10 sec, aim the transmitters (up to 2 additional ones) whose codes you want to store in the keyless receiver, and press the transmitter lock or unlock buttons. Confirm that you hear the sound of the door lock actuators after each transmiitter is stored.
[*]Turn the ignition switch OFF, and remove the key.
[*]Confirm proper operation with the transmitters.[/list=1]
From the service manual, enjoy
SinCityTLX
10-07-2015 01:24 PM
