Replacing Bose System
Old 03-24-2004, 11:30 PM
Type-S_Power's Avatar
I need alil help. I have a Bose System in my 2001 Acura 3.2CL Type-S. The dealership says, I can't remove the Bose system, and replace it with my own custom system, because the Bose system is built into the car. Is there a way around this? should i just cut out the speakers with a saw, so i can start my own project? or should i just leave in the Bose component speakers, and just add Subs?
Old 03-24-2004, 11:59 PM
Fuct in the hed!
Nicky Pass's Avatar
The only thing tricky about Bose is that the amp is matched to the speakers. The dealer is pulling your dick. I replaced alll of my speakers with JL stuff. I think what the dealer meant is that its all or none....if you remove the bose...you have to take it ALL out.
Old 03-25-2004, 09:04 AM
vsokolov's Avatar
Yes there is a way around it, you ether leave your factory radio or change it, if you leave it you will need a 4 chanel amp and new speakers. If you change it you will need new radio then you can run speakers of the stock radio or also add a 4 channel amp to run the speakers of the amp.
Old 03-25-2004, 02:24 PM
hey Vsokolov, I want to rip out the whole bose system, and replace it with my own custom setup. i noticed, that the speakers are like built-into the car frame. how should i go about tackling this job? by the way, right now, i have a RF Folgate amp, and 2 JL 18w3s i want to install in the trunk. i also might go with some JL components for the door panels.
thank you
Old 03-25-2004, 02:57 PM
Vector02's Avatar
HU? You can remove them just fine...takes a few tools, but you won't hurt anything.
mada51589
05-03-2022 08:54 PM
02-25-2020 09:57 AM
cycdaniel
12-17-2019 10:58 AM
yahelou
09-06-2015 09:12 PM
NSolace
09-03-2015 08:02 PM
Quick Reply: Replacing Bose System
