Replacing 3.2 CL Speakers
Old May 13, 2001 | 10:47 PM
DR's Avatar
DR
9th Gear
I’m interested in upgrading the speakers in my 3.2 CL (2001 Model). I want to start by replacing the set of rear speakers to see if this will improve the sound quality and if no, then I will replace the two sets of speakers in the doors. I do no want to go through he trouble of replacing the head unit or amp.
There are three sets of speakers a friend suggested I listen to (all are 6”x 9” three-way speakers): 1.) Infinity Kappa 693.1i 2.) Rockford Fosgate HPC1 & 3.) Polk dX9.
I would like to get your thoughts on replacing the rear speakers with 3-way speakers and on the 3 pairs of speakers above.
Old May 13, 2001 | 11:10 PM
aaron's Avatar
SILVER
if you replace your speakers in the back with after market, they will be four ohm, and the factory are two ohm, which means your amp will put out half the power, therefore, you have decreased your sound quality, further, if you are after better sound quality, you should replace front speakers in general, because they are infinitely more important than the rear speakers., There is a slight possibility you may be able to get your hands on some soundtream front components, they used to make aftermarket 2 ohm speakers.
mods include:
Xtant 6.5" components front and rear
xta603x
2 xtant 12" X series subs
plexi box front and rear with 2way mirror, sliding amp rack
clifford avant guard 4 alarm:AEM CAI and pulleys
Comptech headers on the way
Old May 14, 2001 | 09:05 PM
kix S's Avatar
I agree, the 6 x 9's are more for rear fill. If you replace your front or rear speakers, you will most likely need an amplifier to get the sound you want. The aftermarket speakers usually require more power.
I tried to only replace the rear speakers in my last car, and the speakers started clipping because the head unit wouldn't supply enough power. So then I added an amp, and soon I couldn't hear my front speakers over the rears. To make a long story no-so-long, I ended up replacing everything and adding a sub.
What do you want quality-wise out of the system? I think the mids and high sound fine, but the system just doesn't have enough bass. Also it doesn't do very well at high volume. If it's a more full-bodied sound, or just more boom you want, I'd add a sub. If you really want all-around high quality, powerful sound, I'd replace everything. You might be able to get away without adding a subwoofer.
Also, if you decide to change the 6 x 9's, pay attention to the magnet size. Honda didn't leave us much room for a bigger speaker, which is why I went with Alpine SPS 6939S. They drop in perfectly.
Good luck, I hope this helps.
kix S
2001 Acura 3.2 CL Type S
Silver/Ebony
Sans "3.2 CL Type S" Badges
Retired: 1995 Mazda Protege LX
AndrewS
19
Mar 14, 2024 06:59 PM
jpadilla
3G RLX (2013+)
Nov 18, 2017 07:13 PM
Pegon95
Sep 15, 2015 01:54 PM
iRaw
ILX
Sep 5, 2015 12:10 AM
asahrts
Sep 4, 2015 05:55 PM
