To replace factory rear sub?
Old Oct 15, 2001 | 05:03 AM
typeSmaximum's Avatar
What size is it, 8"? Could I simply change it out with another better 8" or fit a 10" in the same place without changing the rest of the sterio? Has anyone done this for better base and factory look? I may then get some tweeter pods at a later time.
Thanks.
Old Oct 15, 2001 | 12:04 PM
oracion's Avatar
The OEM sub is very thin. I'm not sure if you can find one like that.
Old Oct 15, 2001 | 04:30 PM
has anyone done this? The back hangs into the trunk, so I think if one was thicker, it would be ok.
Old Oct 16, 2001 | 12:08 AM
shawhite's Avatar
i believe that there was a post about this same topic the other day check it out...see if this helps any
http://www.acura-tl.com/forum/showth...threadid=24270
Old Oct 16, 2001 | 05:29 AM
Thanks, at least I have the correct size now. They say http://www.illusionaudio.com/, though I can't find anything?
Old Oct 16, 2001 | 02:48 PM
Las Vegas TLS's Avatar
When I see this subject come up, I always think of Bose car audio being rated at 1 ohm. If someone where to swap out the factory Bose speakers and keep the factory head unit/amp, remember that 1 ohm is going to be less effiecient than 4 ohm speakers.
When Acura uses a 100 watt Bose amp for the sub woofer, it is rated at 1 ohm. In theory if you where to run it in 4 ohms it would only produce 25 watts.
I think maybe a good choice would be to try to use the lowest ohm speaker as possible. Maybe the Orion HCCA series speakers?
Old Oct 16, 2001 | 03:08 PM
NSXNEXT's Avatar
It's not gonna happen...The torsion bars that support your trunk run underneath the sub. There is no room for an aftermarket sub.
Unless your willing to have someone gut your trunk, put hydraulic lifts to support your trunk lid, you're not gonna get another sub in there. Look how freakin shallow the factory sub is. It not even as thick as a normal 6.5" midrange speaker.
Old Oct 16, 2001 | 03:25 PM
Brewboy's Avatar
Old Oct 16, 2001 | 09:21 PM
NSXNEXT's Avatar
Originally posted by Brewboy
I didn't forget the agony you went through. I'm waiting on Ron to finish up a few jobs before he tackles mine. See bottom of sig.
Old Oct 16, 2001 | 11:37 PM
shawhite's Avatar
i understand that it is shallow but illusionaudio makes a sub that looks exactly like the sub that is in the tl...except it only comes in 10 or 12 inches....
Old Oct 17, 2001 | 12:10 PM
Closer's Avatar
You really need to stick your head in your truck and look at this sucker. Nothing aftermarket will fit there unless you get a torch and cut the crossmember thats behind the sub. Once you look at it, you'll know what everyone is talking about.
Old Oct 17, 2001 | 01:56 PM
Brewboy's Avatar
Actually the cross member is fairly easy to get out. Just drill out the 4 spot welds with a 1/2" bit or so and it will fall right off. To put back on if you need to later, just bolt it back in place thru the holes you just drilled.
Old Oct 17, 2001 | 02:49 PM
Closer's Avatar
if you cut this sucker out, with the tension bars for the trunk still
work? I know they're fastened to the cross member, but don't
know if it has to be connected to work.
Old Oct 17, 2001 | 03:16 PM
Unhappy
Thanks for all the feedback. Would be nice to upgrade, and still look stock. The stock system is not very good, and the bose in other cars like Infiniti is much better? Not sure I want to go all out with the audio system, but starting to look like I have to if I eant better sound.
Old Oct 17, 2001 | 05:36 PM
Brewboy's Avatar
Not sure what your asking, but I don't see a reason to remove the cross member and leave the tension rods in place. If you remove both, no, the trunk would not stay open as is, so you would have to add hydraulic lifters or actuators or ? to help keep the trunk open.
Old Oct 19, 2001 | 10:38 AM
t.diddy's Avatar
I replaced the 9" stock with a 10" pioneer free air subwoofer with some minor modification to the rear deck sheet metal. The cross member was removed and the torsion bars were mounted to the metal speaker cage using the existing gray plastic clip. Trunk still opens and closes normally.
Sub is currently hooked up to the OEM amp, but will soon be upgraded. Sound is much improved, system has a deeper truer bass.
Old Oct 19, 2001 | 12:52 PM
Closer's Avatar
perfect. thanks.
Ofcourse, you'd get this. Got any pics?
Old Oct 19, 2001 | 01:52 PM
t.diddy's Avatar
I forgot to mention, I had to cut away some of the plastic from inside of speaker grill in order for it to sit flush and keep the stock look.
Old Oct 19, 2001 | 04:09 PM
Sweet, I knew someone did this! You did all the work yourself, how long did it take? I didn't understand how you re-mounted the bars?
cobra10363
Jul 23, 2024 04:13 PM
wilztlxs
Dec 1, 2015 09:16 AM
scionxb3003
Oct 2, 2015 05:50 PM
mav888
1G RDX (2007-2012)
Sep 8, 2015 11:49 AM
brjones9
Sep 3, 2015 07:30 PM
