CL: remote wire
Old Aug 5, 2010 | 01:41 AM
03type_s6speed's Avatar
remote wire
what are you guys using for the remote wire?
Old Aug 5, 2010 | 07:57 AM
mattastick's Avatar
Do you just need a remote turn on for your amp? From stock or aftermarket hu?
Old Aug 5, 2010 | 10:42 AM
on1wheel01's Avatar
For stock radio you could take it to the radio fuse in the fuse panel
Old Aug 5, 2010 | 02:19 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
as long as you don't use too thin of a wire, the 12v remote trigger signal is not very strong, I've used speaker wire in the past and other random wires. Are you triggering off the stock head unit or an aftermarket?
Old Aug 5, 2010 | 07:56 PM
im installing a new amp just to power my sub in the trunk. And keeping the original amp to power the speakers. Since the OEM amp is in the trunk already, i was wondering if i could just tap into the (white/yellow) radio switch... im getting my info from --->> http://web.archive.org/web/200307131...net/sound.html
also OEM head unit
Old Aug 5, 2010 | 09:15 PM
tangsauce's Avatar
Yup you can tap into the stock amp. It's closer too.
Old Aug 6, 2010 | 09:04 AM
(Mid-Atlantic)
Absolutely
Old Aug 6, 2010 | 10:24 AM
OverGloc's Avatar
On my 02 Type S i use the BLUE wire going to the BOSE sub amp.
Old Aug 6, 2010 | 11:50 AM
i need help... ok so i wired up everythin correct. (ive installled a few simple amp & sub combos b4 but never with a LOC). I wired the battery to the amp, check. Ground to the gas pump covering, check (mayb that isnt metal).. remote wire conected to the radio fuse, check. LOC has 6 wires wired the + & - for RR and + & - RL wires on the LOC correctly to the amp wiring harness..maybe the 2 extra are ground wires? idk they werent mentioned in the instructions. RCA cables are ran from the LOC to the amp...and of course my amp wires from sub to the amp.
am i missing something?
seems as though im getting no power. Also the inline battery fuse is in place and all fuses have been checked..
any help much appreciated!!
Old Aug 6, 2010 | 12:46 PM
mattastick's Avatar
Grab a DMM and start checking voltages. If you have DC voltage into the amp, then that's step 1 and your ground is good. Is your amp even coming on? If not, you need to check your amp's power and ground for 12+v DC, and the remote wire for roughly the same voltage (radio must be on for this to happen). Next check your amp's output. If you're getting AC voltage out, then you're in good shape. If not, check the loc for AC voltage on the RCA outs. For the RCA's put the positive lead on the inside of the RCA connection and the negative lead on the outside. My guess is you won't have anything there, based on your description, but I'm just guessing.
As for the LOC connections, I have no idea, never used one.
Old Aug 7, 2010 | 07:35 PM
andrewcjduong's Avatar
The remote wire is one of the yellow/white with silver dots on the cable that's connected to the stock bose amp. You need to tap into it. You gotta find out which one's the one where it's off when the car is off because there are 2 yellow/white with silver dot wires. I used a multimeter to find out. This is on my 2001 CL-S though.
Old Aug 7, 2010 | 07:38 PM
I believe I had the same problem as you. You need a really good ground. In the trunk, there's that door that's from the seat. Below it is the flap or w/e of where all the plastic carpet crap is. Lift it up and you'll see a bolt with a black ground wire already connected to that. Unscrew it and sand the hole and around the bolt so that's it's clean. Then screw on your ground wire to that along with the previous ground wire that's already connected to that. Should work now. That's what I did.
Old Aug 7, 2010 | 07:44 PM
Here's a photo of the bolt if you can't find it.
Old Aug 25, 2010 | 03:59 PM
jeremyhall217's Avatar
6th Gear
im using 16 guage speaker wire. i twisted both sides of the wire together and went from my rem wire on my stereo to the rem of the amp. it works great. you can go a little smaller with the wire but i wouldnt go any smaller than 18 guage. that should work great for you. hope it helps
Jul 16, 2017 07:33 AM
SUPRMN84
Oct 7, 2015 09:46 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
