Remote Wire
Old Feb 26, 2006 | 05:12 PM
victorvu's Avatar
Exclamation Remote Wire
Where is the Remote Wire located on the 2002 TL TYPE S. I have a wire that works for the car but dont know which is the correct wire. It turns on but to reset or restart the amp you need to turn off your engine. SOME HELP!
Old Feb 26, 2006 | 05:19 PM
demolition_x's Avatar
Agean Blue Bishes
wire it to your power antenna wire if you have a aftermarket deck, or wrap the wire around an accessory fuse like your wipers.
Old Feb 27, 2006 | 12:21 AM
victorvu's Avatar
but if i wrap it in something like that the amp will be on as long as my car is on. Im trying to get the correct remote wire so when i turn the deck on the amp turns on and when i turn the deck off the amp turns off
Old Feb 27, 2006 | 12:26 AM
NYZGREATST's Avatar
Sig Rho's Finest
blue wire that goes into ur headunit.
Old Feb 27, 2006 | 11:05 AM
Agean Blue Bishes
yea well if its to an accessory fuse then when ever the car is on the amp will be on. or you can wire it to your deck.
Old Feb 27, 2006 | 11:18 AM
Jonesi's Avatar
From the sticky at the top of the page shows:
Old Feb 27, 2006 | 04:41 PM
victorvu's Avatar
so ill just run the blue wire to my amp as the remote thanks.
Old Feb 27, 2006 | 07:27 PM
victorvu's Avatar
the actual remote wire isnt the blue one for the 02 TL TYPE S (which i have) i just connected it with the orange wire which is the power remote. It is working now and thats how i want it to work. When i turn my deck off my amp turns off. Thanks for the Diagram.
Jul 16, 2017 07:33 AM
SUPRMN84
Oct 7, 2015 09:46 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
